ᐅ Which construction company builds with Poroton blocks? (North Rhine-Westphalia) Thanks for any information.
Created on: 22 Jun 2018 22:16
Hausbau5678H
Hausbau567822 Jun 2018 22:16Good evening :-)!
We are still at an early stage of our house planning and currently believe that building the external walls with Poroton (36.5cm (14.4 inches)) is the best option for our house.
We will be building relatively close to a busy road, and there is also a railway line nearby – so sound insulation is our top priority. (Energy efficiency is generally standard in all newly built homes nowadays).
From our research so far, we have found that Poroton external walls apparently (?) offer the best sound insulation. We would appreciate other opinions or confirmation on this.
So far, we have found very few home builders who construct with Poroton. Could anyone recommend a reliable company for NRW (Rheinisch Bergischer Kreis)?
We are very grateful for any help.
You can probably tell from my post – we are complete beginners and open to any suggestions or advice.
Many thanks 🙂
Many thanks 🙂
Hausbauer122 Jun 2018 22:31If soundproofing is that important, I would rather consider calcium silicate brick with an external thermal insulation composite system (ETICS) or even a cavity wall construction.
Hausbau5678 schrieb:
(Energy-efficient houses are basically standard nowadays for new builds).
From our research so far, it seems that Poroton exterior walls (?) offer the best sound insulation performance. We welcome other opinions or confirmations here.Sound insulation is achieved through mass. Porous materials won’t provide that. Calcium silicate brick (sand-lime brick) is your friend.
However, the wall alone is not everything. Glass, roller shutter boxes, and other components also need to be properly addressed. So don’t focus solely on the wall.
Poroton, at least the high-density types (filled, perlite, etc.), are less common in our region. With calcium silicate brick, you’ll have better availability in North Rhine-Westphalia.
Hausbau56788 Jul 2018 10:00Thank you for the help. We have now found some good suppliers and have also decided to focus on soundproof windows.
