ᐅ Wall structure 36.5 cm Poroton T8 including facing brick
Created on: 29 Jan 2021 10:10
SebastianLiesa
I’m new here and have already browsed the forum a bit for my question, but haven’t found anything quite suitable so far.
We are in the final stages of working with our construction company, and one of the bigger topics for us is the wall construction.
We definitely want a brick or brick slip finish – but because of the quality, we are leaning towards real bricks.
Using a T8 block (36.5cm (14.4 inches)) with brick, the wall thickness ends up just under 50cm (20 inches).
We are a bit unsure whether that might be too thick and possibly look odd. Does anyone have experience with this?
And what are your experiences regarding the indoor climate with this kind of wall construction?
11ant30 Jan 2021 16:59
What is still missing is what motivated the change of mind.
nordanney
30 Jan 2021 17:25
SebastianLiesa schrieb:
24cm (9.5 inches) masonry
12cm (5 inches) mineral facade insulation with fleece
1cm (0.4 inches) air gap
11.5cm (4.5 inches) facing bricks
That's nearly 50cm (20 inches) again. Why? Are you aiming for passive house standard? Otherwise, I don’t understand the 24cm (9.5 inches) masonry. The air gap is unnecessary.
guckuck2
30 Jan 2021 18:34
Is it really necessary to insist on building with Poroton (24cm plus insulation) here? Has the "indoor climate" marketing had an effect?
Personally, I don’t see 50cm (20 inches) as a problem. With a double-shell construction, you are always over 40cm (16 inches). In my opinion, a few centimeters more or less shouldn’t be a big concern.
nordanney
30 Jan 2021 18:44
guckuck2 schrieb:
Personally, I don’t see 50cm (20 inches) as a big deal. With a cavity wall construction, you’re always above 40cm (16 inches). In my opinion, a few centimeters more or less shouldn’t be a concern.
Well, with calcium silicate brick, it would be only 41cm (16 inches). That means quite a bit of space is lost. Not to mention the different lighting effect and the look with thinner exterior walls. The 50cm (20 inches) that the original poster calculated has only disadvantages.
Nordlys
30 Jan 2021 20:09
There is a dividing line running roughly across the country: north of it, they use white materials like aerated concrete blocks (such as Ytong) or calcium silicate bricks, while south of it, they use Poroton or similar clay blocks. However, warm, dry houses can be found with both types.
WilderSueden
30 Jan 2021 20:56
By now, you can see Ytong in at least one house in almost every new housing development here in the south. The distinction is no longer as clear as it used to be.
