ᐅ Which Billy bookcases are suitable for small spaces?
Created on: 25 Mar 2024 18:07
neben
neben
25 Mar 2024 18:07
I am planning to install new shelves in my small apartment and have been considering the Billy shelves from Ikea. My question is: Which of the Billy shelves are particularly suitable for small spaces where space is limited but the area should still be used efficiently? I am especially interested in recommended widths, depths, and heights, as well as any practical additions or variations that make the most of the space without overcrowding the room or making it look even smaller. Any tips on choosing or experiences with different Billy versions for small rooms would be very helpful. Thanks!
Tobias
25 Mar 2024 19:11
For small rooms, the Billy shelves with a depth of 40cm (16 inches) are especially suitable because they are not too wide. You can choose the height depending on the room height; 80 or 106cm (31 or 42 inches) often fit well.
Additionally, combining them with doors is recommended to visually reduce clutter.
U
uslis47
26 Mar 2024 07:34
Hello!
This is a very well-asked question, as the Billy shelves do indeed offer several options suitable for small spaces. Generally, the narrower models with a width of 40 cm (16 inches) are the best choice because they take up less room in depth. These shelves come in heights of 80, 106, and 202 cm (31, 42, and 79 inches).
I often recommend the medium height of 106 cm (42 inches) for small rooms, as it provides enough storage without visually overwhelming the space.
Tobias schrieb:
For small rooms, the Billy shelves with 40 cm depth are particularly suitable,
This is absolutely true because the 28 cm (11 inches) depth is often too shallow when you want to store larger books or boxes. The 40 cm (16 inches) depth offers a good compromise between storage capacity and space requirements.
Furthermore, you can equip the shelves with additional adjustable shelves and even use doors to conceal less attractive items.
If the ceiling is particularly high, you can use the 202 cm (79 inches) height model and utilize the top compartments for storage that is rarely needed.
Regarding the visual effect, choosing the shelves in white and avoiding overcrowding helps. Mirror surfaces next to the shelves or light-colored walls also enhance the sense of space.
If you like, I can also explain the adjustments with doors, glass, or extensions.
andre3
27 Mar 2024 09:53
In addition to the previous posts, I would like to add the following:
For small rooms, the Billy models with a depth of 28cm (11 inches) and 40cm (16 inches) are clearly the most suitable, with 40cm (16 inches) often being the more practical choice when more storage space is needed and there is enough room for it. A depth of 28cm (11 inches) is mainly recommended for items with little depth or for decorative purposes.
uslis47 schrieb:
I often recommend the medium height of 106cm (42 inches) for small rooms because it provides enough storage without visually overwhelming the space.
This is an important point. I would also suggest choosing the height so that the shelf does not touch the ceiling directly to maintain an airy feel.
Furthermore, I recommend using modular elements from the Billy series, such as single shelves combined with top shelves or doors for enclosed storage. This helps keep small rooms organized and allows for flexible use.
In addition, there are corner versions that help make good use of room corners without taking up unnecessary space. If available, targeted use of corner Billy shelves is advisable.
Due to their shallow depth and clean lines, the shelves do not appear bulky.
As a general rule: width 40cm (16 inches), height up to 106cm (42 inches), depth according to storage needs but not larger than 40cm (16 inches). Add doors or closed compartments as needed.
