ᐅ What to do if screws keep loosening in your Billy bookcase?
Created on: 28 Feb 2020 08:42
Flosan53
I have an issue with my IKEA Billy shelf where the screws holding the back panel tend to loosen repeatedly. The shelf is relatively stable, but when I shake it or it is slightly loaded, I notice the screws become looser, and I have to tighten them again. I have already checked that I’m fully tightening the screws and sometimes even use a small washer. However, this doesn’t hold them securely in the long term.
My question is: What can I do to prevent the screws on Billy shelves from constantly loosening? Are there any special techniques, materials to help secure them, or other tips you would recommend?
I would appreciate it if anyone has experience or advice on how to fix this issue permanently.
koduga
28 Feb 2020 15:18
I can fully understand how annoying it is when something keeps wobbling like that. I had the same issue once, and what helped me was filling the screw holes with some wood filler and, after it dried, drilling pilot holes very carefully. Since then, the screws hold much tighter, and the problem is almost gone.
Maybe this could work for you too?
LOJOPAR
29 Feb 2020 08:47
Regarding screws that repeatedly loosen in Billy-style shelves, here is a brief guide to effectively address the issue:
1. Remove the screw and inspect the hole.
2. If the hole is stripped, first fill it with appropriate wood shavings or toothpicks coated with wood glue.
3. After drying, carefully reinsert the screw.
4. Alternatively, a metal threaded insert can be used if the shelf is frequently loaded.
5. For extra hold, apply a medium-strength threadlocker (e.g., blue Loctite).
It is important not to overtighten, as this can cause further damage to the material. This approach extends the shelf’s lifespan and prevents the need for repeated tightening.
Foster63
29 Feb 2020 10:09
LOJOPAR schrieb:
Alternatively, a metal threaded insert can be used if the shelf will be frequently loaded.
This is a very good tip. Metal threaded inserts provide significantly better anchoring. However, you should pay close attention to the exact dimensions to ensure the inserts fit properly and securely.
Flosan53
29 Feb 2020 13:49
Joshbe schrieb:
1. Use screws with a slightly larger diameter, if possible.
Thanks, I had thought about that as well. However, I’m concerned that using screws with a larger diameter might weaken the material too much. Does anyone have experience with how large you can go without compromising the stability of the particleboard?
LOJOPAR schrieb:
It’s important not to overtighten, as this can cause further damage to the material.
I’ll definitely keep that in mind, thanks for the advice!
Khalil
1 Mar 2020 07:31
A small tip: I also used self-adhesive felt pads under the screw heads – this helps prevent loosening due to vibrations. Sometimes it’s the little things that make a difference :-)
lofar
1 Mar 2020 14:23
Use larger screws only if the hole remains stable. Otherwise, fill the hole with wood glue and wooden dowels. Don’t forget to use threadlocker.
