ᐅ What to do if the back panel of a BILLY bookshelf breaks?
Created on: 13 Jan 2018 09:13
Dujofar
Dujofar
13 Jan 2018 09:13
I recently noticed that the back panel of my IKEA Billy bookshelf has cracked in one spot. The unit no longer stands completely straight and feels unstable. My question is: What can I specifically do to properly repair a cracked back panel on a BILLY bookshelf or at least stabilize it enough so the shelf stands securely again without losing its functionality? Are there any proven methods, materials, or replacement parts you would recommend? I would like to avoid replacing the entire bookshelf since it is otherwise still in good condition.
Thank you in advance for your advice!
maureo
13 Jan 2018 09:21
You can replace the back panel or reinforce it by adding a thin plywood board. Just screw it in from the inside, and the shelf will become stable again.
bujufa
13 Jan 2018 10:02
A break in the back panel often indicates excessive stress or improper handling during transport. It’s best to get a new back panel board from a hardware store, as it is usually just a thin hardboard panel. Make sure it has exactly the same dimensions. Additional reinforcement can be added using small metal brackets at the corners to prevent future breaks.
Kinbu
13 Jan 2018 11:47
maureo schrieb:
You can replace the back panel or reinforce it additionally with a thin plywood sheet.
This is a good approach. I would add that the original back panel of the BILLY shelf is only 3 mm (0.12 inches) thick and made of hardboard. If you use a plywood sheet, it should not be too thick; otherwise, the back could become too heavy, and the screws might not hold properly.
It is also important to ensure all edges are smooth before attaching it. You can stabilize cracks or broken areas with wood glue and thin wooden strips, provided the shelf still has some solid parts.
If you do it yourself, you can also apply wood glue along the broken edges and secure the back panel with several small screws and washers to better distribute the load.
If possible, use new screws as well, since old ones might have stretched over time due to movement.
bauku
13 Jan 2018 14:36
Yay! 🙂 I’m very familiar with this problem! My tip: get a thin plywood sheet (4 mm (0.16 inches) is enough) and make a new back panel from it. This will actually make the shelf even more stable than before. Just cut it to size, sand the edges, and attach it with small screws and wood glue. Super efficient and a lot of fun if you enjoy fixing things yourself! Good luck, we can do this! 🙂
Dujofar
14 Jan 2018 08:29
Thanks for the tip, I hadn’t considered that it really needs to fit precisely.
Kinbu schrieb:
You can stabilize cracks or breaks with wood glue and thin wooden strips.
Is that still advisable if the break extends over half of the back panel? I’m a bit worried that even with a repair, the stability might remain insufficient. What do you think?
Furthermore: Would it theoretically be possible to use a thin metal plate as a replacement? Or is that generally not a good idea due to the weight and installation?
