ᐅ What to do about wobbly BILLY shelves?
Created on: 19 Jul 2018 20:37
Finbardra
Finbardra
19 Jul 2018 20:37
I have several BILLY shelves from IKEA that have started to become wobbly over time. The problem occurs especially when weight is placed on some of the middle shelves or when the unit is moved. Of course, I have already checked that all screws are properly tightened, which is mostly the case. Still, this annoying wobbling remains.
Could you please explain in detail what the best course of action is in such a situation? Are there any special reinforcements or tips recommended by IKEA, or should I consider my own solutions? I would like to avoid replacing the shelves completely, as they are otherwise still in good condition.
Thank you in advance for your help!
Sepele
20 Jul 2018 14:22
Hello Finbardra,
regarding your topic "What to do about wobbly BILLY shelves?" I’m happy to provide a short guide that should help reduce or fix the wobbling.
1. Check the floor surface: Often, the shelf stands on an uneven floor. Small felt pads or furniture shims can help level out any irregularities. This helps prevent rocking.
2. Tighten screws and anchors: Even if you’ve already done this, double-check thoroughly. Sometimes the fastening points on the back panel loosen. The screws holding the back panel are especially important for stability.
3. Secure the back panel: For BILLY shelves, the thin back panel is key to stability. If it has come loose or warped, reattach it and, if necessary, add small nails or even a thin board as reinforcement.
4. Use additional brackets: You can screw small metal brackets into the corners. This greatly increases stiffness without affecting the shelf’s appearance.
5. Add more shelves as reinforcement: Extra shelves provide more stability as they act like stiffeners, reducing flexibility.
Summary:
Finbardra schrieb:
Könnt ihr mir bitte detailliert erklären, was man in so einem Fall am besten tun kann?
So you’ve already thought about tightening the screws, which is good—you should pay special attention to that.
If you want, I can also send you a specific list of screws and bracket types that have worked well for me.
Best regards!
FAZAR
21 Jul 2018 09:48
Hello Finbardra,
Your issue with the wobbly BILLY shelves is a common problem that can usually be fixed quite well with some attention to detail. I’m writing this in detail because you asked for a thorough response.
The stability of the BILLY shelf mainly depends on four factors:
1. Floor surface: An uneven floor causes tilting or wobbling. Even small irregularities can be problematic since the shelf is relatively lightweight and slender when assembled.
2. Back panel condition and attachment: The thin particleboard back panel acts as a shear panel, preventing the shelf from tipping. Often, the back panel detaches from the side panels, or the small nails holding it loosen with frequent movement.
3. Connection points: The shelves are made of several components held together with dowels and screws. These can easily loosen, causing wobbling.
4. Load distribution: Unevenly loaded shelves or particularly heavy contents can reduce stability.
Specifically, you should do the following:
- Tighten and reinforce connections: Two-inch (5 cm) wood screws can strengthen existing joints, especially to secure the shelf supports.
- Completely replace or reinforce the back panel: If the back panel has deteriorated, consider making a replacement from a 3 mm (1/8 inch) plywood board or a thin MDF panel. Additional metal corner brackets can significantly reduce lateral twisting.
- Attach to the wall: IKEA always recommends securing BILLY shelves to the wall, which both prevents wobbling and increases safety. Simple wall anchors or triangular brackets screwed into the wall work well for this.
- Additional shelves and possibly cross braces: An extra shelf in the middle or a cross brace at the back can make the whole structure much more rigid.
Finally: The “wobbly” effect usually comes from small play in the joints, which can be eliminated by targeted screwing and reinforcement. Also check whether the shelf is standing directly on a carpet, as the base may shift when compressed.
Please let me know exactly how your setup looks (Is it attached to the wall? How many shelves are installed?) so I can assist you more specifically.
FAZAR
Gauel
22 Jul 2018 19:33
Hello Finbardra,
I would like to add to this because I am very familiar with the principle from my own experience, and I think FAZAR explained it very well.
I completely agree. Above all, I want to emphasize that the wobbling is often caused by a loose back panel, which is rarely checked consciously.
If you haven’t already securely fixed the shelf to the wall, this is really the most important step. It’s best to combine this with your previous inspection:
- Check that all the small nails securing the back panel are properly in place. Replacement nails can be bought cheaply at IKEA or hardware stores if some are missing or loose.
- If the back panel is already damaged or warped, replace it with a new one.
Additionally, I recommend installing brackets (about 40x40 mm (1.6x1.6 inches)) on the back, screwed to both the shelf and the wall. This makes the shelf practically impossible to wobble.
If you move or transport the shelves frequently, don’t forget to recheck all screws and fastenings after setting it up. Even slight loosening of the connection can quickly cause wobbling.
Best regards!
