I have a problem with my BILLY shelves, which have warped quite a bit in my living room. The middle sections in particular are sagging, even though I don’t think the weight of my books is excessive. My question is: What can I specifically do to prevent or fix this warping?
Do you have any advice on whether the shelves should be replaced or if there are easier ways to restore their stability? I would like to know the best approach for dealing with warped BILLY shelves, especially which materials or reinforcements could help without having to take the entire unit apart.
binmi schrieb:
What can I specifically do to prevent or fix this deformation?Hey, I’m very familiar with the problem of sagging BILLY shelves! The thin particleboard just bends under the weight when you put too many books on it—but don’t worry, there are a few handy tricks.
I’d recommend adding a central support, for example small wooden battens fixed underneath the shelves. Sometimes just this simple reinforcement is enough to stop the sagging. Alternatively, you can use metal brackets on the sides for extra support.
And no worries, you usually don’t have to take everything apart; you can often add these supports during assembly.
A quick tip: If you need new shelves anyway, look for stronger options made from plywood (multiplex) — these hold more weight without bending and also look nice! 🙂
binmi schrieb:
What can I specifically do to prevent or fix this deformation?Hello binmi,
This topic resonates with many because the shelves of BILLY bookcases often aren’t designed for very heavy loads. The typical shelves are about 16 mm (0.6 inches) thick and made of particleboard, which allows for some flexibility.
To prevent deformation, I recommend the following:
1. Reduce the load or distribute it evenly instead of stacking only in the middle.
2. Install additional middle supports, such as small wooden blocks or metal brackets, to better transfer the load.
3. If replacement is possible, switch to high-quality shelves made of solid wood or plywood, as these bend less or not at all.
4. Add rear reinforcements if feasible.
These measures are helpful for both beginners and experienced furniture owners.
It is also important to check the correct tension of the back panel, as it significantly contributes to the overall stability.
I hope this helps! If you want, I can also give you recommendations on where to get replacement shelves.
Warped BILLY shelves can best be prevented by installing a central support beam. Alternatively, you can replace the shelves with thicker laminated wood panels.
Avoid point loads; it is better to distribute the load evenly. Check the back panel to ensure it is properly seated – this significantly increases stability.
leomo schrieb:
I would recommend adding a support in the center as well Interesting, but do you have any reliable data or practical experience to back that up?
Basically, I think it makes sense to take a closer look at the physical load limits of the shelves. A flexible particle board will become brittle over time with repeated bending, which can then cause not only deformation but also breakage.
alvalo schrieb:
If replacement is possible, switch to high-quality solid wood or plywood shelves In my opinion, that is the best solution—although not exactly cheap. However, the question remains whether a complete replacement is economical or sensible if the shelf is only lightly loaded.
I would also ask: What exactly are the loads? Are these just books or also heavier items? Because that is crucial for choosing the right solution. Perhaps a combination of reinforcement and replacement makes sense.
Only supporting or only replacing? A well-informed decision based on actual usage is recommended.
