ᐅ What should you do if the screw holes in a BILLY bookshelf are stripped?
Created on: 4 May 2021 08:23
LUMIVIN
LUMIVIN
4 May 2021 08:23
I noticed that some screw holes in my BILLY shelf have torn out of the wood. Since this significantly reduces stability, I am looking for a long-term solution to securely fix the screws again.
Has anyone had experience with repairing torn screw holes like this? Which materials are suitable, and what procedure would you recommend, especially for furniture made of particleboard or MDF, as is common with BILLY?
I would appreciate detailed tips, as I want the repair to hold firmly over time and not fail again.
Traman4
4 May 2021 09:12
Hello, for stripped screw holes in the BILLY shelf, a simple method usually helps: apply wood glue and fill the hole with wood shavings or toothpicks, let it dry, then screw in again. Alternatively, you can use special dowels or plugs if the hole is very large.
PRA64
4 May 2021 10:45
Regarding the topic of "stripped screw holes in BILLY shelves," I would like to share a brief guide that also works well for furniture fronts made of particleboard or MDF:
1. Clean the stripped hole from any loose wood splinters.
2. Fill the hole with fine wood chips or shortened toothpicks coated with wood glue.
3. Press the material firmly into the hole and let it cure for at least 24 hours.
4. After that, you can carefully screw in the screw again – it is best to pre-drill to avoid further stripping.
Important: Avoid using screws that are too large, as they could further damage the material. Another option is to use so-called wood repair kits (epoxy wood filler), which create a stable base.
A brief note: Most BILLY shelves are made of particleboard with a foil veneer. Therefore, it is advisable not to saturate the area with glue to prevent warping.
lorena
5 May 2021 07:52
The question of repairing stripped screw holes in a BILLY shelf is more fundamental than it might seem, especially if the shelves are older or frequently loaded.
In general, I recommend the following approach if durability is important:
First, assess the extent of the damage—whether the hole is in MDF-like material or decorative particleboard. Since both materials are relatively soft, simply filling the hole with toothpicks followed by wood glue only provides limited support.
Alternatively, a wood epoxy or a special wood filler can be applied into the old hole. After it cures, sand the surface smooth and slightly pre-drill to better insert the screw, which significantly improves the hold.
One important point: do not use screws that are too long or too thick, as this can further damage the material. Try to stick as close as possible to the original screws.
For additional stability, if possible, consider installing so-called furniture connector dowels or knock-in nuts—though this usually requires more craftsmanship and possibly modifying the shelf.
I would be interested to know whether only individual screw holes are affected or if the shelf has been under constant load. If multiple spots are damaged, this could indicate material fatigue and suggest a more extensive repair might be necessary.
Torsten45
5 May 2021 13:19
PRA64 schrieb:
various wood repair kits (epoxy wood filler) that create a stable base.
That is absolutely correct.
To add: BILLY shelves are typically made of particleboard with a veneer finish. These are particularly prone to tearing out around the screw holes.
Screw holes that are stripped or damaged can be permanently repaired using epoxy wood filler. You mix the filler according to the manufacturer's instructions, fill the hole completely, and let it cure. Afterwards, you can accurately pre-drill and screw in again. This effectively prevents repeat tearing.
Additionally, it is advisable not to use screws that are too thick to reduce mechanical stress. For maximum durability, screws with fine threads are recommended.
When the screw itself bears the load, a very strong connection can be achieved through the solid filler material.
Repairing with wood glue and wood shavings is a cheaper alternative but significantly less durable.
In summary, I would recommend epoxy filler if a long-lasting repair is the priority.
