ᐅ What are the differences between the Brimnes versions from IKEA?
Created on: 24 Oct 2017 18:27
DINAME
DINAME
24 Oct 2017 18:27
I am currently looking into the IKEA Brimnes range and would like to get more detailed information about the different variants. In particular, I am interested in understanding the exact differences between the models, such as dimensions, usage options (e.g., as a wardrobe, sideboard, or bed with storage), storage features, material and build quality, as well as design and functional details.
I understand that Brimnes is a series covering various furniture pieces, but I would like to know which specific variants are actually available and what key points buyers should consider when choosing between them. For example, whether there are differences in drawer depths, stability, or assembly.
I would appreciate a well-informed, more detailed breakdown of the Brimnes variants to help me make a well-informed purchasing decision.
tra_nina
24 Oct 2017 19:05
DINAME schrieb:
I am particularly interested in the specific differences between the models, whether in terms of dimensions, usage options (e.g., as a wardrobe, sideboard, or bed with storage), storage possibilities, material and workmanship quality, as well as design and functional details.
The Brimnes series from IKEA includes several types of furniture with different functions and configurations. The main variants are:
- Wardrobes: Various sizes (e.g., height between approximately 190 and 236 cm (75–93 inches)), some with sliding doors or hinged doors, featuring shelves and hanging rods.
- Beds with storage boxes: The Brimnes bed mainly varies in size (e.g., 140x200, 160x200 cm (55x79, 63x79 inches)) and includes built-in storage drawers under the slatted frame, which are highly practical.
- Dressers/sideboards: Different widths and heights, offering up to six drawers, suitable for storing clothes or other items.
The materials and finishes are basically the same: particleboard with a foil coating in white or black-brown. The stability is solid but not comparable to solid wood.
Assembly instructions vary little; the fastening system is consistently similar. Drawers differ in number and size depending on the version.
In short: the main differences within the Brimnes series are in the function and dimensions of the individual pieces rather than material quality or style.
I would primarily consider the room size and storage needs when choosing the right variant.
risar
25 Oct 2017 08:42
tra_nina schrieb:
The Brimnes series from IKEA includes several types of furniture with different functions and designs.
Exactly. I would add that the Brimnes variants are often distinguished by practical details that matter in everyday use:
- Some cabinets have soft-close doors, which is especially convenient with frequent use.
- The storage beds offer different opening mechanisms – drawers are generally easier to operate than lift-up panels, which can be important depending on a person’s height or physical condition.
- The dressers sometimes differ in drawer arrangement (one large drawer or several smaller ones at the top), which affects how the storage space is organized.
It is also useful to note that the surface can be somewhat prone to scratches, so gentle use is recommended. This is not a difference between variants but a characteristic of the series.
If assembly concerns you: the steps are similar across all variants. Assembly usually takes between 1 and 2 hours, depending on the model and experience. The instructions are quite clear, though some variants have slightly more parts.
In summary:
- The variants are well thought out functionally and cater to different living needs.
- Larger variants offer more storage space, while smaller ones save space.
- The main decision factors are usually storage requirements, room layout, and preferred opening type.
meson
25 Oct 2017 09:11
Brimnes mainly differs in type (bed, wardrobe, chest of drawers), size, and storage solution. Material and design are largely identical. For beds, you can also choose between different mattress sizes.
chenlen
26 Oct 2017 14:53
Regarding drawer depth and stability: The drawer depth varies between Brimnes dressers and beds depending on the model. For example, bed drawers are often deeper to provide more spacious storage, while dresser drawers tend to be shallower and designed for clothing.
The stability is comparable across all versions and solid for furniture in this price range. However, different weight capacities are relevant. Beds can support more weight (approximately 200 kg (440 lbs)) than dressers (about 10–15 kg (22–33 lbs) per drawer).
Assembly effort is generally similar; larger models require more time and care due to a higher number of parts. Following the instructions carefully is important, as stability can be compromised otherwise.
My advice: If storage for heavy items is important, consider Brimnes practical but not designed for the heaviest loads.
