ᐅ Visible screw connection on shower fitting
Created on: 15 Apr 2019 00:29
Kaskadeur
Kaskadeur
15 Apr 2019 00:29
As a newcomer to the forum, I have a question about the proper installation of shower fittings. Two bathrooms in our house were recently renovated with relatively high-quality exposed fittings. In both showers, part of the thread and a gap between the nut and the fitting are visible (see pictures). It seems likely that limescale and dirt will accumulate there. Is this considered a defect, or do I have to accept it? The contractor’s response has been delayed for a long time.
Thank you in advance!
Chromium bathroom fitting with measuring tape, close-up of the connection
Close-up of a chromium bathroom fitting with measuring tape on stone surface
Bookstar
15 Apr 2019 06:35
In my opinion, not a defect.
tomtom7915 Apr 2019 07:11
The thread should have been shortened. If the tradesperson refuses, do it yourself—grab a grinder or hacksaw and cut off 3 thread turns.
Lumpi_LE
15 Apr 2019 11:55
It's the same for us too; I think we even have the same fixture. It didn't bother me, but if it bothers someone, as Tomtom mentioned, it can be changed quickly.
hemali2003
15 Apr 2019 14:40
I thought it was supposed to be like that
Knöpfchen16 Apr 2019 08:08
If the thread is shortened to fix this aesthetic defect, please make sure not to shorten the thread that is now visible.
Instead, the thread on the other side, which is screwed into the wall, must be shortened by this difference.
Otherwise, your sealing surface will be damaged.
