ᐅ Ventilation in New Construction (Central vs. Decentralized), Noise Disturbance
Created on: 20 Jun 2016 20:41
Kiri123
I am currently considering the ventilation system for our planned new build (details: Kfw 70, 2 full floors + basement + unheated attic, hipped roof, 200m² (2,150 sq ft) living space). We live in a rural area and like to keep the windows open sometimes, so we don’t necessarily have to rely entirely on mechanical ventilation.
I am torn between a central controlled mechanical ventilation system with heat recovery, a central exhaust with decentralized supply air, and decentralized supply/exhaust with heat recovery. My requirements are:
• Ventilation of bathrooms (master bathroom, children’s bathroom without windows, and guest toilet without windows) with demand-controlled ventilation based on usage
• I want to avoid having to open windows every few hours while still maintaining high indoor air quality
• Not too noisy, as I am very sensitive to noise when trying to sleep
• I am also sensitive to dry air; for example, I cannot tolerate air from air conditioning or sports halls very well
Below are the pros and cons of each system as I see them:
Central Controlled Mechanical Ventilation with Heat Recovery
+the most mature system
-expensive (I estimate about 10,000 to 13,000 Euros)
-more complex planning, including suspending and boxing in ducts
-(I heard from a provider of decentralized ventilation systems: as soon as I turn up the ventilation in the living room, more warm air is blown into the bedroom – not desirable)
-the indoor air quality in the prefabricated houses with controlled ventilation that we visited was always poor. That makes me skeptical
Central Exhaust with Decentralized Supply Air
+cheaper (maybe 2,000 to 3,000 Euros?)
+should meet minimum requirements
-energy wasted (or can I reuse the heat energy somehow? I am planning to install an air-water heat pump for heating and hot water production. Maybe the heat can be used here in a useful way). I was advised against a complete exhaust heat pump. Perhaps combined exhaust/fresh air heat pumps exist?
-cold air from decentralized supply? (I have read that with proper planning this is no problem because the supply air mixes “appropriately” with the existing indoor air)
-somewhat contradicts the idea of energy-efficient houses. Still, it’s probably more efficient than constantly having windows tilted open.
Decentralized Ventilation with Heat Recovery
+If I simply install one of these ventilators in the living-dining area, the master bathroom, and the children’s bathroom (+ exhaust in the toilet), the minimum requirements should be met. I estimate about 3,000 Euros (1,000 Euros per unit)
-if I want to cover all other rooms to avoid window ventilation entirely, it gets more expensive (maybe ~8,000 Euros) and:
-I would have many holes in the building envelope
-I hesitate to install these devices in bedrooms or children’s rooms because I think they may be too noisy.
Could you please help me with the decision? Maybe by sharing your experience or confirming or disproving some of my points? I would also like to see different ventilators in practice. Do you have any tips? I heard it might be possible somewhere in Berlin, but I live in the postal code area 5xxxx.
I look forward to your opinions.
Kiri
siegreich
13 Feb 2017 15:04
Sebastian79 schrieb:
You certainly won’t get sick from that...
We have prepared the climate control system in the house for four rooms – all the bedrooms plus the open-plan living and dining area.
Climate ducts, condensate drainage, and electrical wiring – everything is nicely installed flush in the walls and ready to connect. It didn’t even cost 500 euros...
Hello Sebastian,
we are also in the planning phase. May I ask you a few questions? (It seems like we have a similar approach):
1. Do you have a central controlled ventilation system with heat recovery? We are considering that.
2. We are building the ground floor (parents) and upper floor (us) as separate apartments. Would it still make sense to install a central controlled ventilation system?
3. We also want to have air conditioning. Did you install the ducts yourself, or do companies usually handle that separately from selling the equipment?
Thanks for your reply.
Greetings from the Baden region.
Simon
RobsonMKK13 Feb 2017 16:24
@siegreich Sebastian is no longer active here
Mycraft13 Feb 2017 16:41
No, he has said goodbye from here...
Bieber0815
13 Feb 2017 21:23
siegreich schrieb:
We are building the ground floor (parents) and the upper floor (us) as separate apartments. Would it still make sense to have a central mechanical ventilation system with heat recovery?
I would give each residential unit its own mechanical ventilation with heat recovery. After all, you want to control the air exchange independently. Then, for each apartment, you can choose either a centralized or decentralized system, depending on preference.
