ᐅ UD - Drywall Profiles for Shaft Cladding, Are They Appropriate?
Created on: 12 Nov 2021 12:31
DASI90Hello everyone,
We want to cover the shaft ourselves, which includes the technical installations and especially the laundry chute. Due to the space constraints inside the shaft, every centimeter counts. Does anyone know if UD and CD drywall profiles (28mm (1.1 inches)) can be used for shaft cladding with single-sided drywall panels? I have only read that these profiles are typically used for suspended ceilings. Or are the thinnest options the UW and CW profiles with 50mm (2 inches) plus drywall panels?
DASI90 schrieb:
we want to cover our shaft, which contains the technical installations and especially the laundry chute, as a DIY project. Due to the setup inside the shaft and the limited space, every centimeter counts. Does anyone know if UD and CD drywall metal profiles (28mm (1 inch)) can be used with single-sided drywall sheathing as shaft cladding? I have only read that these profiles are usually used for suspended ceilings. Or is the thinnest option actually the UW and CW profiles with 50mm (2 inches) plus sheathing?
Regards I also covered my knee wall on the upper floor using UD 27/28mm (about 1 inch) and CD profiles. Secure the UD profile solidly to the masonry, and it should work. Whether it meets any structural building regulations, I obviously don’t know.
