ᐅ Turn on the underfloor heating at the thermostat/controller.
Created on: 12 Nov 2023 22:53
Bertram100
Bertram100
12 Nov 2023 22:53
I had underfloor heating installed later in the screed on the upper floor, which has a controller up there (or whatever that thing is called where the pipes are connected in a row and there is another row on top with extra indicators).
What do I need to do to turn on the underfloor heating on the upper floor? The indicator tubes are set all the way at the top, showing zero flow.
Could someone possibly help from a distance? Thanks in advance!
13 Nov 2023 00:14
Hmm, I would guess it is at 100% flow from a distance. 0 flow basically means off.
dertill
13 Nov 2023 07:41
Bertram100 schrieb:
upstairs has a controller (or what is the name of the thing where the pipes are connected in a row and above there is another row with additional indicators).
Heating circuit manifold with flow meters.
If all the valves there are fully open and no flow is present, the circuit at the bottom or directly behind the heater still needs to be opened.
However, the installation of the underfloor heating normally also includes pressure testing, filling, and commissioning. Has nobody done that?
Bertram100
13 Nov 2023 08:58
Thanks 🙂
Well, everything was installed three years ago and it worked fine back then. But since then, I haven’t turned on the heating upstairs. Now I’m not sure how to turn it back on.
I’ll check if the main line is still closed. Thanks for the tip.
Bertram100
13 Nov 2023 15:37
Bertram100 schrieb:
I'll check if the main line is still closed
The main line is open. I have now realized that the blue "knobs" are just caps that come off easily if turned far enough. Now I can only tell from the indicators that there is no flow anywhere. But how I can turn anything if the "knobs" are only decorative, I don’t know either.
KarstenausNRW
13 Nov 2023 15:52
Bertram100 schrieb:
The main pipe is open. I just realized that the blue "knobs" are only caps that simply fall off if you turn them far enough. Now I can only read from the indicators that there is no flow anywhere. But how to turn them when the "knobs" are just decoration, I don’t know either.
As they say, a picture is worth a thousand words. So go ahead, take some photos of everything. Just two or three sentences of text don’t really help much ;-)
