ᐅ Tips for Upgrading Malm Furniture?
Created on: 15 Jun 2022 08:37
arnold43
arnold43
15 Jun 2022 08:37
I am currently planning to upgrade some of my IKEA Malm furniture to improve their functionality and durability. I am particularly interested in tips for reinforcing the drawer slides, the best methods for securely attaching additional handles, and recommended materials or tools suitable for these upgrades.
Since the Malm series is made from particleboard, I have some concerns about stability when drilling extra holes or attaching heavier add-ons.
Who here has experience with upgrading Malm furniture? Which approaches have proven effective, and what mistakes should definitely be avoided?
I look forward to your well-founded tips and practical advice!
RonJarrett
15 Jun 2022 10:44
To reinforce Malm drawers, I recommend attaching metal brackets on the inside of the carcasses to increase stability under heavier loads. Standard drawer slides are generally designed for moderate weight capacity.
arnold43 schrieb:
Concerns about stability when adding extra drill holes or mounting heavier attachments
When drilling, use a drill bit with a pilot tip and apply gentle pressure to avoid splitting the material. It’s best to pre-drill first and then use suitable screws, ideally short wood screws or those with special threads designed for particleboard.
Tools: A cordless screwdriver with adjustable torque is useful to prevent over-tightening. Zinc-plated metal screws are more durable than basic wood screws.
When attaching additional handles, make sure to check that the drilling positions align with the internal metal frame to ensure a secure hold.
Ethan
15 Jun 2022 12:03
I would like to add that it is advisable to take precise measurements of the components before retrofitting and to pay attention to the existing drill holes. Some Malm models already have hidden holes that can be used to attach accessories without making new holes.
RonJarrett schrieb:
Use a drill with a pilot bit and apply light pressure to avoid splitting the material.
I can fully confirm this. Additionally, I recommend covering the spot lightly with tape before drilling – this helps reduce surface tears.
For drawer extensions, heavy-duty slides can be retrofitted, which are available online, to increase load capacity. However, this often requires minor modifications to the cabinet.
If the fittings do not come with suitable tools, a ratchet with Torx bits is very useful for precisely loosening and tightening screws.
floga
15 Jun 2022 14:17
I also tried working with Malm furniture, but at first, I was a bit unsure because of the thin panels.
arnold43 schrieb:
Concerns about stability when making additional drillings
My experience: It’s important to handle the furniture very carefully since small mistakes become visible quickly. However, with some patience and proper preparation, retrofitting works surprisingly well. For my Malm dressers, I used small threaded inserts to attach the handles more securely. This provides much better support than just screwing directly into the particleboard.
If you’re interested in the topic: I had a great experience with handles that can be reinforced using small metal plates—you can often customize these at hardware stores.
I understand if this seems tedious at first, but it’s definitely worth taking it step by step and investing a bit more time.
Gino38
16 Jun 2022 09:21
For retrofitting Malm furniture, brief and precise:
- When drilling, always use a drill bit with a small tip, about 3-4 mm (0.12-0.16 inches), and drill slowly to avoid exit splintering.
- Extend the durability of the screws by pre-drilling with a perpendicular angle drill bit to protect the edge.
- When installing handles or accessories, carefully check the load direction to align the screws accordingly.
- For drawer slides, it is recommended to use galvanized or stainless steel runners specifically designed for the Malm depth.
These points are basic but very effective if followed.
naujon
16 Jun 2022 10:56
Here is a short tutorial for retrofitting Malm drawers, focusing on increased stability and comfort:
1. Preparation:
- Check all the dimensions of your furniture piece and note down the depth, height, and width of the drawers.
- Gather stainless steel screws, insert nuts, and suitable metal brackets.
2. Drilling:
- Tape the drilling spot with painter’s tape to prevent splintering.
- Use a drill bit with a small diameter (about 3 mm (1/8 inch)) for pre-drilling.
3. Reinforcing the sides:
- Installing metal brackets inside the drawer sides increased stability by more than 20% for me.
4. Drawer runners:
- For older Malm furniture, replacing the plastic runners with new metal runners from a specialized store is worthwhile, as the plastic runners weaken over time.
5. Upgrading handles:
- Insert nuts ensure a secure hold, especially for frequently used doors and drawers.
6. Final steps:
- After installation, recheck all screws and readjust everything a few weeks later.
Common mistakes include using screws that are too large, which can split the material, and missing pre-drilling.
