ᐅ Tiling over Bitumen Waterproofing: Installation Methods Without Thickening Layers and Cracking Issues
Created on: 15 Nov 2025 22:05
deWhisperD
deWhisper15 Nov 2025 22:05A two-layer torch-applied bitumen waterproofing was installed on my balcony. The top layer is slate-coated. Due to the staggered overlaps of the two layers, noticeable height differences occur at regular intervals of about 40cm (16 inches): normally the surface is two layers thick, but at the overlaps it is even four layers thick.
I was advised to first lay a drainage mat on this waterproofing and then apply a several-centimeter-thick (several-inch-thick) layer of drainage concrete to later install tiles. However, I have concerns: bitumen and concrete react differently to temperature changes, especially in summer. In combination with the existing height differences, the concrete overlay might not be able to move freely – which, in my opinion, could cause stress and therefore cracks.
How do you assess this risk?
And based on your experience, which alternative construction methods are better suited to create a stable and durable tiled surface on this bitumen waterproofing?
Hi,
your concerns are completely justified. The problem with adding a screed layer on top of a torched bitumen waterproofing membrane lies in the different material properties: bitumen is thermoplastic, meaning it expands when heated and contracts when cooled. Concrete, on the other hand, is very rigid and cannot accommodate these movements. If you also have existing height differences, this leads to localized stress points where the bitumen membrane layers overlap four times. This can indeed cause cracks in the screed or later in the tile surface, especially with large temperature fluctuations in summer or winter.
The option with a drainage mat and several centimeters of screed only theoretically works if the screed is designed as a “floating” layer — completely decoupled from the waterproofing and possibly guided by decoupling mats at specific points. However, with the height steps, it becomes extremely difficult to achieve a uniform structure without local stress concentrations. A surface leveling beforehand is almost always necessary here; otherwise, the height differences remain and the concrete mass “works” against the waterproofing.
Alternative construction methods that work better in practice would be:
A professional alternative is therefore not necessarily “adding more concrete on top” but rather a combination of decoupling and flexibility. It is especially important that the waterproofing is not mechanically damaged.
Good luck!
- Flowable, self-leveling thin-layer systems based on bitumen or special balcony/terrace coatings that are applied directly over the bitumen waterproofing. These systems are flexible enough to accommodate the movements of the bitumen membrane and can then be tiled.
- Thin-set tile adhesives on decoupling mats or flexible composite mats that compensate for height differences and absorb the movements of the waterproofing.
- In cases of very irregular overlaps, carefully flame off or mechanically remove the four-layered spots beforehand to create a more even base before applying a screed or mortar layer.
Good luck!
