ᐅ Has anyone ever adapted Kallax units for use on a balcony?
Created on: 1 Jan 2021 09:12
teono8
teono8
1 Jan 2021 09:12
I would like to start a topic that has been on my mind for a while: Has anyone ever adapted a Kallax shelf for use on a balcony?
More specifically, I am interested in how you have made the shelf weather-resistant or modified it to withstand outdoor conditions reasonably well. I am concerned that the original untreated wood might deteriorate quickly due to moisture, sun, and wind.
Does anyone have good experiences, tips, or maybe even ideas for a durable sealant or other protective measures? I plan to use the shelf without major alterations but would still like to know what has proven effective in extending its lifespan.
Thanks in advance for your feedback!
Tobias
1 Jan 2021 09:48
Simply treat with wood preservative stain, preferably applying several coats.
Place the base on small feet or tiles to prevent direct moisture from rising from below.
Kolepau
1 Jan 2021 10:33
It's great that you brought up this topic! 🙂
I painted my Kallax unit with weatherproof paint and also made a custom cover from tarpaulin fabric. This way, everything stays in great shape and still looks cool.
Take your time – it’s definitely worth it!
lomin
1 Jan 2021 11:05
I understand you well; the concern about the material is definitely justified.
I was also unsure whether Kallax would be too sensitive for the balcony. In the end, I treated it with regular wood oil, but I take the shelf down in winter.
How large is your balcony? Perhaps mobile solutions could also be worth considering here.
Fingers crossed you find a suitable solution.
PRA64
1 Jan 2021 12:17
Here is a brief overview of how to prepare Kallax for balcony use:
1. Primer: Apply a wood primer or wood preservative primer to the raw material.
2. Stain or paint: Use a weather-resistant wood stain or varnish to protect against UV rays and moisture.
3. Sealing: Seal the edges with clear silicone to prevent water penetration.
4. Base: Place the shelf on feet or water-resistant pads to avoid direct contact with the floor.
Make sure each layer dries thoroughly, and it’s best to apply the stain or varnish several times.
Common mistakes include not sealing the edges and placing it directly on the floor.
teono8
1 Jan 2021 12:50
PRA64 schrieb:
Here is a brief overview of how to prepare Kallax for the balcony
This is really helpful, thank you!
What about the stability when moving the shelf around frequently? I've heard that the feet of Kallax can sometimes be less sturdy.
