ᐅ The Malm bed only squeaks when it moves – how can I reduce the noise?
Created on: 6 Apr 2022 08:37
golunoHello everyone,
I have an IKEA Malm bed, which is great overall, but as soon as I move on it—whether turning over or getting up—it squeaks quite loudly and annoyingly. The squeaking only occurs when there is movement; it is completely silent when still. I have already tried tightening the screws, but without much success. So, it’s likely not a loose fastener but rather friction between the parts.
My question: How can I reduce the noise on the Malm bed when it only squeaks during movement? What steps or materials are truly effective for dampening the sound without damaging the bed? Perhaps you have experience with lubricants, felt pads, or other solutions? I would really appreciate concrete tips and advice.
The issue with squeaky beds, especially with IKEA furniture like the Malm, often arises from friction at the joints or the connecting clips between the side panels and the bed base. Since screws have already been checked, I recommend applying suitable lubricants at the contact points between wood and metal or wood and wood.
A commonly effective solution is a neutral-smelling silicone spray or wax, which reduces friction without damaging the wood. Alternatively, dry graphite powder can be used, as it is non-sticky and does not attract dust.
Important: Clean the surfaces before application to remove dust and oily residues, then apply sparingly. Additionally, small felt pads at contact points can help minimize direct wood-on-wood contact.
Those with DIY experience can also cushion the screws from the inside with thin felt strips or foam rubber, which dampens noise and prevents abrasion.
Giagau schrieb:
A commonly proven solution is a neutral-smelling silicone spray or wax that reduces friction without damaging the wood.That sounds plausible at first, but it raises the question of whether silicone sprays might attract dust over time and potentially make the problem worse. Do you have any concrete experience or studies on this?
It would also be sensible to check the entire bed frame for any warping or stability issues. Slight wobbling could be the cause of the noises. Simply applying lubricants then only treats the symptoms, not the root cause.
I would recommend a systematic approach: first test all the joints, then focus on rubbing exactly where the squeaking originates. And not just tightening the screws, but also inspecting the wooden parts themselves for cracks or material fatigue, which can creak and squeak under load.
ODINFLO schrieb:
That sounds plausible at first, but I wonder if silicone sprays might attract dust over time and possibly make the problem worse? Do you have any concrete experience or studies on that?Interesting point, which I hadn’t considered. Do you think it would be better to use something like dry graphite powder instead? Would that also be practical for use with wood?
Giagau schrieb:
Alternatively, dry graphite powder can be used, as it is not sticky and doesn’t attract dust.The tip about felt pads also sounds good. I remember that a thin felt pad placed between the slatted frame and the bed frame almost completely eliminated the squeaking in my slatted frame.
So, I will first systematically check exactly where the squeaking is coming from, and then try felt pads and dry graphite powder. Thanks in advance for the solid advice.
