We have finally been living in our newly built house for two weeks now. We have underfloor heating throughout the entire house and a digital thermostat in every room. All thermostats are set to 21 degrees Celsius (70°F) throughout the house, and everything works fine overall. As soon as the thermostats reach 22 degrees Celsius (72°F), they switch off—except in the children’s room. There, we have noticed that the temperature easily rises to 23 degrees Celsius (73°F) overnight, and the floor remains constantly warm compared to the other rooms.
I have already contacted the company that installed everything for us, but it will probably take some time before I receive a response. As a curious person, I would really like to understand what could be causing this or what the reason might be.
Did you check the valves??AD1988 schrieb:
Because I am currently living in the house with my wife and a 2-year-old child and don’t want to just tinker with the heating system.It’s not tinkering, it’s testing! Have you read the user manual?Never touch a running system!
But your system is not working.
boxandroof11 Nov 2019 18:03AD1988 schrieb:
What I’m still wondering is whether it makes sense to limit the temperature to a maximum of 35 degrees Celsius (95°F)?What do you mean by that? Is it a setting or your observation?What kind of heating system is this, exactly?
1.1 has an endpoint of 65 degrees Celsius (149°F) flow temperature at -15 degrees Celsius (5°F) outside temperature. This is a setting for a gas burner in a 1990s house with radiators. Who set this up?
Happy sweating. No wonder the floors are noticeably warm.
Reducing it to 35 degrees Celsius (95°F) only helps to a limited extent. With this heating curve, those temperatures are already reached at around 10 degrees Celsius (50°F) outside. So the heating is already simmering during the transitional season, and the room thermostats dutifully clamp shut. When they do open, it gets very warm at foot level...
boxandroof schrieb:
What do you mean by that? Is it a setting or your observation?It is set that way.B
boxandroof11 Nov 2019 19:14AD1988 schrieb:
It is set that way.Sounds reasonable. If the heating curve is correctly adjusted, then this setting becomes irrelevant.Similar topics
