We have finally been living in our newly built house for two weeks now. We have underfloor heating throughout the entire house and a digital thermostat in every room. All thermostats are set to 21 degrees Celsius (70°F) throughout the house, and everything works fine overall. As soon as the thermostats reach 22 degrees Celsius (72°F), they switch off—except in the children’s room. There, we have noticed that the temperature easily rises to 23 degrees Celsius (73°F) overnight, and the floor remains constantly warm compared to the other rooms.
I have already contacted the company that installed everything for us, but it will probably take some time before I receive a response. As a curious person, I would really like to understand what could be causing this or what the reason might be.
boxandroof13 Nov 2019 20:55AD1988 schrieb:
That means I wouldn’t be able to heat any warmer via the thermostat even if I wanted to.Yes, that’s exactly the point. That’s why during balancing, leave the thermostats alone and fully open. There should be constant flow in all rooms. With a heat pump, the recommendation is to remove the thermostats completely.If it actually gets too cold at -10°C (14°F), you will need to adjust the supply temperature. According to DIN standards, 35°C (95°F) is the design temperature; in your case, 40°C (104°F) was planned, which is not a problem with a gas heating system. You will find out what is sufficient when the time comes.
