ᐅ Utility room: how to plaster and paint the walls?
Created on: 26 Jul 2017 21:44
bvb09
bvb0926 Jul 2017 21:44
My utility room with the heating system, hot water tank, and related equipment is a separate room behind the garage. Therefore, the wall was only constructed by the main contractor as agreed. We already had enough work with filling and painting inside the house, so in the utility room, the untreated gypsum board remained on top of the OSB board. Now that the heating system is installed, it’s difficult for me to fill and paint this area properly.
In terms of size, I want to use the room not only for storage but also for a workbench. I find paint on filled gypsum board quite sensitive even inside the house. What would you advise me now to finish the room? I can fill and paint the ceiling without problems because I can still reach it well, and sensitivity is less of an issue there. But how about the rest?
Robin
Kellerraum mit Heizungsanlage, Rohren, Zähler und Tür
Gartenfreund
27 Jul 2017 07:35
I would leave it as it is. After all, it’s not living space.
Bau-Schmidt
27 Jul 2017 09:46
Wow, the technology was installed here without much consideration.
Nordlys
27 Jul 2017 11:43
Gartenfreund schrieb:
I would leave it as it is. It’s not living space anyway.
Me too. K.
bvb0927 Jul 2017 22:24
That's true, but it feels a bit off to me because it looks unfinished. In the end, I probably won’t be able to make it look good anyway. Thanks for your opinion!
Mycraft27 Jul 2017 22:33
Well, just crossing out "white" would make it look a bit nicer.
