ᐅ Stone dust on concrete pavers cannot be removed.
Created on: 13 Mar 2021 09:44
Chris_Colt
Chris_Colt
13 Mar 2021 09:44
Hello!
Parts of the garden/patio area were paved in September last year. The paving stones are standard permeable concrete blocks.
Without consulting us, the landscaping contractor used stone dust to fill the joints. Unfortunately, this stone dust also settled on the surface, and I can’t remove it. The anthracite-colored stone now looks light gray. I hoped that weathering might help, but unfortunately, that’s not the case!
Does anyone have any suggestions?
hampshire
15 Mar 2021 11:05
The landscaping contractor should provide the solution. I wouldn’t tackle it myself unless it’s something that can simply be wiped or swept away.
Nida35a15 Mar 2021 11:07
The vacuum cleaner doesn’t work; everything is crusted or hard.
The Kärcher cleans out the joints thoroughly,
but you will need to re-grout afterwards.
icandoit
15 Mar 2021 11:16
Notice of defects to the landscaping contractor.
Chris_Colt
15 Mar 2021 14:25
A complaint about defects, etc., is understandable, but I would still have appreciated a tip or recommendation, whether it be a product (acid-based cleaner) or a cleaning method...
When it comes to HDR, one should definitely avoid working on concrete pavers...
MichaHB
25 Jun 2022 18:11
I have the same problem with our paving. The haze caused by the stone dust.
Have you found a solution for this?
Micha
