ᐅ Limodor ventilator can be started automatically (sensor) and manually (switch).
Created on: 27 Dec 2022 15:11
V
vaderle
V
vaderle
27 Dec 2022 15:11
In my new build, a Limodor ventilator (Comfort CNA45/20L60-30) was installed in both the utility room and the bathroom.
Both units have the standard run-on timer module (C-NR) and a humidity controller (C-FR2) installed. The fans start automatically when the relative humidity rises. I do not have a switch to operate the ventilation manually.
However, I would like to retrofit exactly that. I want the ventilator to run both automatically when humidity rises and manually via a switch. Is this kind of retrofit possible?
For lights, wireless switches are common. These are installed between the power supply and the lamp connection, and then the supplied switch can be placed anywhere. No wiring to the light switch is required.
Is something like this also applicable here?
