ᐅ Humidity has dropped dramatically
Created on: 8 Feb 2021 08:27
SaRo2000
SaRo2000
8 Feb 2021 08:27
Hello everyone!
We have now been living in our new house for 14 months and are very satisfied. There is always a lot to do, both inside and outside. However, we have been concerned about the humidity levels in the house for some time.
We had a prefabricated timber frame house built, KFW 55 standard. We also use an air-to-water heat pump from Tecalor with a ventilation system that includes heat recovery. The humidity has dropped to below 20% during winter. As far as we know, the indoor humidity should be between 40% and 60%, partly for the sake of the mucous membranes and overall comfort. According to the technician, we cannot adjust anything further on the heat pump regarding this.
Is using a room humidifier our only option now, or does anyone have other suggestions?
SaRo
SaRo2000
8 Feb 2021 08:49
We ourselves are affected by the low humidity.
8 Feb 2021 08:53
Our indoor humidity is quite low, and we notice it in our mucous membranes. However, we adapt to it seasonally. Better than a constant runny nose. I’m not sure if a humidifier is the right solution, but why not? You could try using a water fountain.
Mycraft8 Feb 2021 09:04
Low humidity is quite common in modern houses, but you might want to check if the airflow of the mechanical ventilation with heat recovery system can be reduced a bit. It’s also possible that you have a simple plate heat exchanger, which could be replaced with an enthalpy heat exchanger. That would make a significant difference.
SaRo2000
8 Feb 2021 09:21
Okay, this is a technical matter. I need to consult with an expert. Thanks 🙂
Bookstar
8 Feb 2021 10:05
Below 20% is already quite bad.
