Development Plan/Restrictions
Plot size = 545 sqm (5865 sq ft)
Slope = minimal, almost flat
Site occupancy index = 0.4
Floor area ratio = 0.8
Building envelope, building line and boundary = see photo
Number of parking spaces = 2
Number of floors = maximum 2 full stories (II or I+D)
Roof type = hip roof / gable roof / pitched roof
Architectural style = open
Orientation = see photo
Homeowner Requirements
Architectural style, roof type, building type = hip roof, townhouse with bay window
Basement, floors = basement, ground floor, upper floor
Number of occupants, ages = 2 adults (30 / 30) and 2 children (2 / <1)
Room requirements on ground floor, upper floor
Office: family use or home office = office in basement for home office
Guests per year = maximum once
Open or closed design = partly open (living/dining area open)
Conservative or modern style = modern style
Open kitchen, kitchen island = open kitchen, kitchen island if feasible (no appointment at kitchen showroom yet)
Number of dining seats = 6 (extendable table for about 8 people)
Fireplace = yes, in living room, acting as a kind of “small” room divider between living and dining areas
Music/sound wall = no
Balcony, roof terrace = terrace on ground floor, to be roofed over / option for roof terrace above bay window (cost issue)
Garage, carport = garage with direct access to house (pantry), separate carport (see aerial photo)
Utility garden, greenhouse
Other wishes = sauna in upper floor bathroom / larger wardrobe area / terrace roofing (type of terrace roofing still to be decided)
Design by: building technician from a construction company and our own ideas
What do you not like? Why?
Cost estimate according to architect/planner = not yet specified
Personal budget for the house, including fittings = 600,000 €
Preferred heating technology = ground source heat pump (GSHP), photovoltaic, optional battery storage
Home automation = KNX (programming and planning by father)
If you had to give up certain details/extensions:
- can give up: roof terrace above bay window / lots of space in the master bedroom / straight staircase (initially planned but currently replaced by a staircase with landing)
- cannot give up: space for children / office
Why is the design like it is now? For example:
Standard design by planner? No
Which of your wishes were implemented by the architect? Office (initially wanted on ground floor, now in basement with light well due to space constraints)
Plot approximately 550 sqm (5920 sq ft), not very large, so trying to get as much living space as possible on a small footprint. That’s why there is a basement, but we didn’t want a “standardized,” square townhouse with a hip roof, instead adding a personal touch with the bay window on the ground floor.
We look forward to input from the forum (so far I have mainly been a silent reader) and thank you in advance.
Regards
JoHa
- Basically the open layout on the ground floor
- Upper floor with relatively large children’s rooms
- Bay window extension on ground floor
- Entrance area > looking for new ideas for a “large” wardrobe due to 2 children and many shoes
- Bathroom layout on upper floor > the planner just sketched a rough idea, nothing concrete yet. However, I want to try to fit a 2-person sauna. Any ideas from the forum?
- Basement layout > what room sizes do you recommend for the basement? How much space is needed, e.g., for technical equipment? Ideas for basement layout?
- Windows > In the current plan, window placement/type has not been a main focus. We want a floor-to-ceiling corner window with a patio door in the ground floor living room.
Regards
JoHa
exto1791 schrieb:
It’s a very specific floor plan with a very spacious hallway and a very large kitchen – the question is whether that suits the overall size of the house.
4.14m (13.6 ft) from the sofa to the TV wall is definitely enough – if it were my floor plan, I would try to make the hallway a bit smaller and maybe choose a different staircase design, so you can have more of the living room. You have more than enough space in the hallway – plus an entrance vestibule and a huge coatroom. Maybe you could use some of that space elsewhere.
I also find the pantry a bit awkward, especially the door to the garage? You would have to walk through the pantry every time you enter the house from the garage and then come out into the kitchen – feels a bit odd, but that’s a matter of taste. Especially since there are two doors into the pantry... I would probably remove the door to the garage as well.
Sure, the kitchen is huge, and you can definitely make something great out of it. There’s even room for a small seating area. If you like a generous kitchen, go for it.
Regarding the upper floor: currently, there’s no space for a large wardrobe in the bedroom. The bedroom’s shape isn’t ideal for a normal wardrobe. You have 3.25m (10.7 ft) of space, but then it gets quite tight near the window and in front of the bed… So I would definitely consider some changes or adjustments there.
I’m not really a fan of walking in and seeing the shower enclosure (probably glass) straight ahead. I don’t think the bathroom layout is optimal, but of course, that’s totally a matter of personal taste. The staircase takes up a lot of space up there. First of all: thanks for the input. We’re considering moving the entire horizontal wall on the ground floor (between living/dining and hallway) about 0.5m (20 inches) to make the hallway narrower, because there really is a lot (too much) space there. That would also increase the distance from the sofa to the TV wall to 4.64m (15.2 ft).
The door between pantry and garage is basically off the table for us now (even after the discussions and suggestions here).
We do like spending a lot of time in the kitchen and currently have a kind of small bar area there in our apartment. So having a small seating corner would definitely be nice.
I agree with you on the bedroom upstairs, that’s definitely something to think about.
The bathroom layout was done by the draftsman, and we haven’t been involved in planning that ourselves at all. But we didn’t like it at first glance, either.
Ysop*** schrieb:
I also think the living room feels too small. I would rather swap the living room and kitchen, but actually, I would redesign the entire ground floor. I would also remove those odd short wall sections on the upper floor in front of the toilet and in the entrance area on the ground floor. Swapping the living room and kitchen is currently being discussed and may be redesigned.
I would make the laundry chute accessible from the hallway. Placing it in the back corner disturbs the toilet user, and that path is too far for lazy people or possibly undisciplined children.
The huge pantry takes up too much space. There is empty space in front of it. The walkway from the kitchen to the dining table is too long.
It makes sense to plan the living room in the quieter part of the house and connect the kitchen to the dining area. Therefore, I would swap the living room and kitchen.
There is a lot of unused space on the ground floor. The hallway is large, in my opinion far too large... I would place the staircase on the south side to capture the southern sunlight, benefiting the entire house.
A guest toilet to the east and the bathroom in the south is a waste.
Definitely try furnishing with your own furniture and make the current kitchen area square. Good idea to have the laundry chute in the hallway. We got the bathroom layout directly from the draftsman and are not satisfied with it at all yet. It will definitely change.
Like your predecessors, I think the idea to swap the kitchen and living room makes sense!
I’m not so keen on the staircase on the south side, because you’ll need shading in summer if there are many windows in the stairwell.
We will also add our own furniture to the first floor plan draft and quickly figure out where the issues still are.
Thanks!
Yes, I’m not even sure what I like better: the porch post right in front of the garage door, or the interior window next to the sofa ;-)Let’s just say the draftsman still needs to get better at using the CAD software 😉 😉
RomeoZwo schrieb:
A shower and toilet in the basement will probably require a macerator pump system. A relatively small one is sufficient for the shower, but it gets more complex for the toilet. It should also be maintained regularly. For that reason, we decided against installing a toilet next to the sauna and went with just the shower. Depending on the location, the pump system used for heating system drainage can sometimes be shared.
By the way, we’re glad we switched from the 1.4 x 2.0 m (4 ft 7 in x 6 ft 7 in) sauna upstairs to the 2 x 2.5 m (6 ft 7 in x 8 ft 2 in) sauna in the basement. Of course, 2 x 2.5 m (6 ft 7 in x 8 ft 2 in) upstairs would have been even nicer, but the floor plan didn’t allow it due to other bathroom requirements ;-) . I’m a bit biased here. My parents (house built around the turn of the millennium) have a sauna in the basement that we hardly ever used because it just wasn’t inviting. Whether we will be able to implement the sauna upstairs or not is still uncertain.
Pinkiponk schrieb:
Regarding the sauna in the basement, I have some biases because I remember those from the 70s and 80s and have never seen a design that I found appealing. But maybe things are different in basements today.
As for the windows, I would like it if you consistently chose double casement windows, and if the patio doors on the ground floor were also double casement. I would also like a second window in your bedroom.
I really like the relatively large hallway/vestibule, as it immediately conveys a sense of spaciousness and openness when entering the house. For example, my husband sometimes uses the term "dead space," which I personally define as "space," and having space is comforting and pleasant, in my opinion.
I would also prefer if the pantry door opened toward the kitchen, because then there would be room between the hallway and the "open-plan area" (that’s how I’m referring to your kitchen/dining/living room combination) for a double casement door.
I would prefer a wider front door since there is room for it, but of course, that depends on the sizes of the other doors and windows and the overall dimensions. Everything should probably harmonize or create a contrast. 🙂Thanks for the input regarding the windows. I really like the suggestion of double casement windows.
I would prefer a wider front door since there is room for it, but of course, that depends on the sizes of the other doors and windows and the overall dimensions. Everything should probably harmonize or create a contrast. 🙂Thanks for the idea about the double casement windows — excellent!
I like your use of the term “space” instead of “dead space” 🙂 🙂
Opening the pantry door towards the kitchen is a good idea. Perhaps with a sliding door? That way, you could really install a nice, wide double casement door.
A wide front door (including a fixed side glass panel) is already on the to-do list for the next meeting with the architectural draftsman.
