ᐅ Residual moisture in walls after two months – explanation?
Created on: 16 Dec 2018 10:25
biotox
biotox
16 Dec 2018 10:25
maybe someone can offer an explanation.
On an interior wall, an area of about 30 x 40 cm (12 x 16 inches) had to have the plaster including insulation (polystyrene foam) removed down to the base wall of the exterior structure. In total, about 4-5 cm (1.5-2 inches) were removed.
Afterwards, new insulation was applied to the wall, and the rest was covered with plaster.
The next day, it was wallpapered with standard textured wallpaper and painted with silicate paint.
The wall was dry beforehand. There are no pipes running there or any other sources of moisture.
Two months later, I happened to notice a crack in the wallpaper exactly around the border of this area. Then I measured the moisture level with a Trotec device and was surprised.
Normal wall values are around 20 digits, but in the new area, it went up to 60-70 digits.
The values increase precisely where the new plaster is behind the wallpaper.
The professional company responsible was informed and inspected the site, but they had no explanation except to tear it open and redo it.
All my logic says that since no external moisture can be coming in, the problem must be in the plaster itself.
But no metal or anything else that could distort the readings was incorporated.
The surface temperature matches the rest of the wall (18-19°C / 64-66°F), which also suggests that the new insulation is working correctly.
Does anyone have an explanation why there is still residual moisture detectable after two months? I have also specifically applied heat to the area to improve the readings, so far without success.
Photos were taken the day of the repair.
Basement wall with cracks, moisture and installation pipe visible
Interior wall with fresh plaster area and uneven surface.
tomtom7916 Dec 2018 16:34
Where is the moisture from the plaster supposed to go if you hang wallpaper right away?
I let it dry completely before applying wallpaper.
biotox
16 Dec 2018 16:49
I would have done that too... but the painter didn’t. However, I’m not sure if the textured wallpaper (woodchip wallpaper) is completely moisture-resistant...
Mottenhausen
17 Dec 2018 11:48
It depends on how the wallpaper was applied, specifically which wallpaper adhesive was used and how thickly it was applied.
Nordlys
17 Dec 2018 12:01
No, Dr. Motte, that’s not the case. The issue is more with the color. If you use a good quality, even something washable, it will be quite impermeable. Not 100%, but still quite close.
Mottenhausen
17 Dec 2018 14:15
Then maybe we should first discuss whether drying out through the wallpapered side into the room would be desirable in this case or not. And I still stand by this: even the best vapor-permeable paint is useless if the wallpaper has already been applied with plenty of paste and all pores are sealed from behind.
Or do you really think that the moisture will somehow manage to get out on its own, and now we just paint over it with something 100% waterproof?
