We received an offer from the builder for additional costs to increase the basement ceiling height and to add a home office including underfloor heating and a daylight window for about 16 m² (170 sq ft) at over 8,000€.
Is this extra charge reasonable?
What should be considered when planning such an extension?
It is a semi-detached house with underfloor heating and an air-source heat pump.
Thank you in advance!
Che.guevara4 May 2016 21:59Do the math!
How many extra bricks are there?
Sebastian795 May 2016 07:29What can you argue against that? My gut feeling is that it’s not an exaggeration – but I would either fully heat a basement or not heat it at all.
it is a 6m x 10.5m (20ft x 34ft) semi-detached house...
in the basement, an office space of approximately 18-20 sqm (190-215 sq ft) is to be heated, the rest will be a small storage room and a technical/laundry room.
I thought that heating the storage room and technical/laundry room would not be necessary.
What disadvantages or problems (can) arise from having only a partially heated basement?
Thank you very much for your help!
Bauexperte5 May 2016 11:18Hello,
The price does not seem too high to me; if anything, it seems rather low. The entire basement ceiling height is being increased to an internal height of 2.50 m (8 ft 2 in), screed and underfloor heating are being installed, and most likely the electrical wiring in the office will be installed concealed in the walls; plus a living space window. I would also recommend having a ventilation system installed in the office.
Keep in mind in your calculations that you will need to transport more excavated soil; I assume the basement walls will not be underpinned to accommodate the increased floor-to-ceiling height.
Regards, Bauexperte
Momad schrieb:
We received an offer from the developer for additional costs related to increasing the basement ceiling height and finishing it with a home office including underfloor heating and a daylight window, approximately 16 m² (172 ft²), for over 8,000€.
It is a 6 m x 10.5 m (20 ft x 34 ft) semi-detached house...
The basement is intended to have a heated office space of about 18-20 m² (194-215 ft²), with the rest being a small storage room and a utility/laundry room.
I thought heating for the storage room and utility/laundry room would not be necessary.
Is the additional cost reasonable?
Regards, Bauexperte
