ᐅ Recess in the screed, 5 cm deep – How is it done?
Created on: 4 Nov 2018 21:56
Bernd2378
What are the options for creating an opening measuring 60x40x5cm (24x16x2 inches) when installing the screed?
The total thickness of the screed is 15cm (6 inches).
Should I build a wooden formwork of 60x40x15cm (24x16x6 inches), leave out the whole area, and then pour 10cm (4 inches) afterwards?
Or should I use something like Styrofoam in the size 60x40x5cm (24x16x2 inches), have it incorporated during the pour, and remove it later?
How is this usually done?
I am a complete beginner in this area and just want to prepare the necessary tools and materials.
Good luck
nordanney
5 Nov 2018 13:37
Bernd2378 schrieb:
But what if the washing machine is running, etc.?
That’s true. But how much water is actually in the washing machine that you would need a pump (there is a water stop valve in the supply hose, right)? A large amount of water can only come from a broken pipe. The same can happen in the bathroom or kitchen – but you don’t have a sump there. And if there is a major leak, so much water will flow that the pump won’t help much anyway.
So just do what everyone else does. Forget about the sump.
Bookstar
5 Nov 2018 16:34
That's exactly right. No risk, no fun.
Anoxio
5 Nov 2018 20:12
Hmm. Honestly, I don’t see the point of having a recessed area if there is no slope. We initially installed two floor drains in our laundry room and, of course, incorporated the necessary slope. This way, we can rinse out heavy dirt with a garden hose; naturally, we also use a squeegee afterwards.
My mother-in-law’s basement has flooded a few times for different reasons. But even there, it’s handled quite pragmatically since the water spreads fairly evenly – they just bring out the wet/dry vacuum to suck up the puddles. I don’t see any advantage to having a depression in the floor, where the water would first have to be pushed into.
I would skip the extra effort.
11ant5 Nov 2018 23:56
Fummelbrett schrieb:
To be honest, I also don’t see the point of such a basin if there is no slope.
Above all: in a 12-liter (3.17-gallon) basin – even if it would basically fulfill the noble idea in principle, it certainly would not in terms of size.
Steven
6 Nov 2018 12:44
Hello Bernd
get a 40mm (1.6 inch) Styrodur board from the building supplier, a long straight piece of metal (similar to a ruler), and a utility knife. Then cut out your measurement and give it to the screed installer, along with a 5 euro note. He will cut out the recess from the screed for you.
Steven
