ᐅ Prefabricated house construction? What budget is required to build one?
Created on: 27 Jul 2014 21:11
Pompeya
Pompeya
27 Jul 2014 21:11
Hello, we have decided to build a prefabricated house. We already had an appointment today with a house manufacturer, which was quite disappointing and would exceed our budget. I wanted to ask if our planning is really unrealistic?
Our budget is 350,000€ (about $380,000).
A plot of land would realistically cost around 100,000€ (about $110,000) in our area, approximately 550m² (6,000 sq ft).
Our idea is a 140m² (1,500 sq ft) house without a basement, with plumbing and flooring done by ourselves if materials are already included in the price.
For additional construction costs (such as fees, permits, connections), we roughly estimate 50,000€ (about $54,000), so we have about 200,000€ (about $217,000) left for the house itself (as mentioned, self-work is possible).
Is this really so unrealistic? After our appointment today, it seems like 500,000€ (about $543,000) is necessary, but we can’t imagine that everyone can spend that much on a house. We don’t want a mansion, but it should be of reasonable quality.
Can anyone recommend a reliable prefabricated house company that fits this budget or specializes in shell houses?
Wastl
28 Jul 2014 08:24
For a high-quality timber frame prefabricated house, 200k is unrealistic. The foundation slab must be included in that. Our house, without the foundation slab or basement, cost about 230k for roughly 135 square meters (with materials for flooring and painting done by ourselves).
Doc.Schnaggls
28 Jul 2014 08:31
I think Wastl is right. EUR 200,000 also seems too low to me if it is supposed to be a high-quality timber frame house.
Our price was EUR 360,000 for 191 sqm (2,056 sq ft), but turnkey, with a basement, heat pump heating, controlled ventilation system, and as a custom-designed house.
Pompeya
28 Jul 2014 08:47
Wastl schrieb:
For a high-quality timber frame prefab house, 200k is unrealistic. The base slab has to be included in that. Our house, excluding the base slab and basement, cost about 230k for 135sqm (with materials for flooring and painting done by ourselves).
If you don’t mind me asking, who did you build with? We really thought that 200,000€ would be enough, as I said, without the basement and additional building costs. Maybe there’s some flexibility on the square meters since 120sqm (1,292 sq ft) would actually be enough for us. We wanted to schedule appointments with Bien-Zenker and Hanlo Haus now, as I believe they might be a bit more affordable.
Wastl
28 Jul 2014 09:03
We built a Hanse Haus. I can give you details via private message. An honest statement from our Bien-Zenker sales representative (who was also a very likable person – we still decided against Bien-Zenker) was: "The good ones all cost about the same."
Skipping the basement usually saves money, but the slab foundation will still cost you around 10,000-20,000 € (about 11,000-22,000 USD).
Bauexperte
28 Jul 2014 09:27
Pompeya schrieb:
Hello, we have decided to build a prefabricated house. We already had an appointment with a house manufacturer today, which was very sobering and would exceed our budget.
You shouldn’t see it only negatively; it’s better to have an honest description of the starting point than to be disappointed later.
Pompeya schrieb:
I wanted to ask if we are really planning unrealistically?
Budget is 350,000€
Land would realistically cost about 100,000€ in our area, approx. 550m² (5900 sq ft)
The plan is a 140m² (1500 sq ft) house without a basement, with plumbing and flooring also done by ourselves, provided materials are already included in the price.
For additional construction costs, we roughly calculate 50,000€, so that leaves 200,000€ for the house (as said, self-construction possible). Is that really so unrealistic? After our appointment today, it seems like 500,000€ is needed, but we can’t imagine that everyone can spend that much for a house. We don’t want a palace, but it should be something decent in terms of quality.
I will assume a solid construction; while good prefabricated house suppliers are not cheaper, they are often more expensive.
Budget: 350,000€ (approx. 350k EUR)
Land: 100,000€ (approx. 100k EUR)
Single-family house, 140 m² (1500 sq ft) living space and KfW 70 standard: 224,000€
Additional building costs: 35,000–40,000€
Painting work done by yourself: 10,000€
Floor coverings done by yourself: 10,000€
Outdoor facilities done by yourself: 10,000€
Reserve for extras: 10,000€
Shortfall: 54,000€
If you expect to provide materials yourself for the interior work, you need to look for suppliers who target that clientele; alternatively, have an architect put the project out to tender. However, this raises the question whether you a) have the necessary knowledge of the required work, and b) the time to carry out these tasks. From my point of view, building a new single-family home should not dominate your life!
Pompeya schrieb:
Can someone recommend a reliable prefabricated house company that fits this price range or specializes in shell-and-core houses?
Why limit yourself to a prefabricated house supplier? That significantly restricts your possibilities to contribute your own labor, beyond painting and flooring...
Best regards, Bauexperte
