ᐅ Practical size for windows and roller shutters (or blinds)
Created on: 6 Jan 2018 17:17
Thomas1980
Good evening,
We are currently planning two fairly large patio doors in our living area.
1.: Height: 2.55 m (8 ft 4 in) Width: 3.20 m (10 ft 6 in)
2.: Height: 2.55 m (8 ft 4 in) Width: 2.40 m (7 ft 10 in)
The plan includes a built-in roller shutter box with a height of 25 cm (10 inches). Flush ceiling lintels are planned in the concrete ceiling. The floor construction measures 20 cm (8 inches). The rough construction height is 3 meters (9 ft 10 in) (from the top of the raw floor to the underside of the ceiling).
The height is composed as follows:
- 20 cm (8 inches) leveling element for screed due to floor construction up to the finished floor surface
- 2.55 m (8 ft 4 in) window/door height
- 25 cm (10 inches) built-in roller shutter box
= 3 m (9 ft 10 in)
My question to the experts: Should I reduce the width of the openings to avoid problems with the roller shutters? For example, instead of 3.20 m (10 ft 6 in), make it 3 meters (9 ft 10 in)?
The other windows in the building are planned by the architect with a width/rough opening of 1.60 m (5 ft 3 in) (double windows).
Thanks and regards
= 3 m (9 ft 10 in)
Thanks and regards
Thomas1980 schrieb:
I don’t want it to sag or require a special custom-made solution either.I think their glass sizes have long since gone beyond the standard 😉
Thomas19807 Jan 2018 00:47Does separation then also mean two roller shutter boxes with two motors?
I am thinking more along the lines of: one box, one shaft, one motor – just two pairs of guide rails and two sections of blinds.
Thomas19807 Jan 2018 02:30Great. I was missing that information. Thanks.
Is it also possible to feed the power cable for the motor into the roller shutter box from above? We operate every roller shutter with a power cable from the utility room (controlled via KNX). The cables are routed through the concrete ceiling and then come out of the ceiling above the roller shutter. Connection to the motor is made via Wago terminal block inside the box. I would like to avoid a junction box and drilling into the exterior wall.
Thomas19807 Jan 2018 10:55Similar topics
