ᐅ Practical size for windows and roller shutters (or blinds)
Created on: 6 Jan 2018 17:17
Thomas1980
Good evening,
We are currently planning two fairly large patio doors in our living area.
1.: Height: 2.55 m (8 ft 4 in) Width: 3.20 m (10 ft 6 in)
2.: Height: 2.55 m (8 ft 4 in) Width: 2.40 m (7 ft 10 in)
The plan includes a built-in roller shutter box with a height of 25 cm (10 inches). Flush ceiling lintels are planned in the concrete ceiling. The floor construction measures 20 cm (8 inches). The rough construction height is 3 meters (9 ft 10 in) (from the top of the raw floor to the underside of the ceiling).
The height is composed as follows:
- 20 cm (8 inches) leveling element for screed due to floor construction up to the finished floor surface
- 2.55 m (8 ft 4 in) window/door height
- 25 cm (10 inches) built-in roller shutter box
= 3 m (9 ft 10 in)
My question to the experts: Should I reduce the width of the openings to avoid problems with the roller shutters? For example, instead of 3.20 m (10 ft 6 in), make it 3 meters (9 ft 10 in)?
The other windows in the building are planned by the architect with a width/rough opening of 1.60 m (5 ft 3 in) (double windows).
Thanks and regards
11ant7 Jan 2018 15:15
Thomas1980 schrieb:
Here is the floor plan of the ground floor with the two windows.
What is the 1.5cm (0.6 inch) supposed to represent – exterior plaster?
For the second emergency exit, the shutters will also need an emergency manual crank.
Thomas1980
7 Jan 2018 15:20
Oh wow. The building authority hasn’t mentioned that yet. Lucky break...
The 1.5cm (0.6 inches) is plaster – you’re right.
