ᐅ Which type of electrical cable is suitable for parking lot lights and an outdoor socket?
Created on: 30 Mar 2021 17:09
Stephan1978S
Stephan197830 Mar 2021 17:09Since pipes are currently being installed for another project, I want to proactively pull the appropriate electrical cable for 5 connected parking lot lights and 1 outdoor socket. I don’t have the lights yet, but they will likely be low-power fixtures to provide subtle illumination of the parking area. What type of electrical cable do I need for this? Suitable for outdoor use. Thanks in advance!
Stephan197830 Mar 2021 17:14Thanks Nordlys and Mycraft!
Stephan197830 Mar 2021 17:18Mycraft schrieb:
Depending on the cable length, consider whether you need 3x2.5 mm² (3x2.5 mm² / 3x2.5 mm²). If you want to be able to switch the lights individually, then 5x1.5 mm² or 5x2.5 mm² would be appropriate. Thanks for the advice! The plan is for the lower 3 lights, the upper 2 lights, and 1 outdoor socket to be powered via a single cable. Would you therefore recommend 5x2.5 mm² (5x2.5 mm²)?
