ᐅ Plastered ceiling: should it be painted directly or covered with a painting fleece (painting fabric)?
Created on: 31 Jan 2017 19:34
Lile08
Lile08
31 Jan 2017 19:34
our ceilings were cast in-situ with concrete and then plastered.
We assumed the plaster could simply be painted over now.
However, the painter suggested it would look better if a painting fleece was applied before painting. This might require some touch-ups in a few corners.
Does anyone have experience with this?
We think the ceiling plaster looks very good. And even if there were a small uneven spot somewhere, it probably wouldn’t be noticeable.
Therefore, we would actually like to avoid the effort and cost of the fiber fleece...
31 Jan 2017 21:37
The painter also wants to earn something
Regards
77.willo31 Jan 2017 23:21
I have looked at both in finished houses and then decided on fleece without hesitation. For walls and ceilings—the difference was clearly visible.
Bieber0815
1 Feb 2017 07:23
Pro fleece +1. It also masks smaller cracks (which can and likely will appear later).
Mycraft1 Feb 2017 07:34
Also here... if you don’t want to apply textured wallpaper, definitely use fleece wallpaper... otherwise, you will see every unevenness.
souly75
1 Feb 2017 10:00
I agree with the two previous commenters. I have fleece installed under the ceiling myself and am happy with it. Neighbors decided against it, and compared to mine, their ceilings look rather unfinished and uneven. I skipped the fleece on the walls in our hallway … time pressure … and will have to catch up later because you can really see everything. Every tiny plaster imperfection. The few extra dollars spent on fleece are worth it.
