ᐅ Photovoltaic system / heat pump – do you have two meters?
Created on: 2 Jan 2021 07:15
chewbacca123
Hello and Happy New Year!
I have a question – since last October, we have had a photovoltaic system on the roof, including a battery storage.
Previously, we had two electricity meters: one for general electricity and one for the heat pump because of the reduced electricity rate.
Our electrician connected the heat pump’s electricity to the general meter due to the photovoltaic system, so we could see how this setup works and whether the heat pump benefits from the solar generation.
In December, we had a consumption of 700 kWh, which is quite high! Our general electricity use is usually around 250 to 300 kWh per month.
I understand that these are the darker months and it should improve from March, with likely much lower electricity consumption as the photovoltaic system generates more and the heat pump uses less.
How do you handle this – do you only have one meter now? Or do you keep the heat pump on a separate meter?
Thanks and best regards
Stefan2.84
5 Jan 2021 07:00
I had an appointment yesterday with a solar energy consultant/salesperson. They said it’s fine to keep the two meters. Usually, it only makes a difference of about 30-40 euros per year.
Regarding the battery storage, they mentioned that you either install it right away or skip it completely. Adding it later is possible, but more complex and therefore more expensive.
I still need to research this topic more to fully understand everything.
guckuck2
5 Jan 2021 07:25
He is right about the battery. It’s not worth it. But if you do decide to get one, do it right away because otherwise, you won’t have a compatible inverter, and when buying as a bundle, you can also include VAT on the battery, which you can't do if you retrofit later.
chewbacca1235 Jan 2021 19:53
Stefan2.84 schrieb:
I also had an appointment yesterday with a photovoltaic consultant/salesperson. He said it’s fine to keep the two meters. Usually, it only makes a difference of about 30-40 euros (USD) per year at most.
Regarding the storage system, he said you either include it right away or not at all. Retrofitting later is possible, but more complex and therefore more expensive.
I still need to read up more on this topic to fully understand everything.
If you go for storage, definitely install it now. We are still getting subsidies for that, 100 euros (USD) back per kWh (for us 1000 euros (USD) out of 5000 euros (USD) total).
Stefan2.84
5 Jan 2021 21:24
Then I’ll wait and see if it still fits within the budget. The plan was actually just to have the roof as full as possible without an attic.
Tarnari5 Jan 2021 21:54
The statement was that if you are going to install a storage system (if any at all), then it should be done now.
I don't think this was advice to get a storage system per se, but rather that if you really want one (for ideological reasons, for example), you should acquire it now.
Stefan2.84
8 Jan 2021 09:55
Yes, although he has already made some "advertising" for the battery storage. He meant that the lifespan (depending on the number of charge cycles?!) has greatly improved. However, I will probably refrain from it.
