ᐅ Should you paint or wallpaper lime-cement plaster?
Created on: 10 Nov 2017 17:07
expose
I have lime-cement plaster throughout the entire house and want to start by painting everything white, possibly adding some accents after moving in.
The idea is simply to paint everything white first or maybe use wallpaper.
What have you done with your lime-cement plaster? Is it worth using silicate paint, or is the difference in indoor climate compared to an emulsion paint rather small? What should I pay attention to?
Does anyone perhaps have experience with wallpapers?
Many thanks to you all
Malz1902
13 Nov 2017 08:48
Deep primer "solvent-free 5L (1.3 gallons)" from the Hagebau in-house brand Go/On—is that sufficient?
13 Nov 2017 09:53
Malz1902 schrieb:
Should I use latex paint for the bathroom and guest toilet? Or is Renovo Kristallweiß sufficient for this?
Renovo Kristallweiß costs €2.40 per liter (0.26 USD/qt)
Alpina Weiß Original €3.80 per liter (0.41 USD/qt)
StoColor In €3 per liter (0.32 USD/qt)
Just get the cheapest stuff from the hardware store.
But don’t be surprised if it doesn’t cover well, requiring more coats, or if it yellows faster or something like that.
kkk272729
13 Nov 2017 10:35
Even a cheap primer is sufficient.
For the final coat, I would only recommend high-quality paints, although I personally cannot recommend Knauf, for example.
Nordlys
13 Nov 2017 13:49
Just use the cheapest stuff from the hardware store. But don’t be surprised if the coverage isn’t great and you need to apply more coats, or if everything yellows faster or something.
What he lists is not cheap. Sto is a professional-grade paint, Renovo Crystal White is of the same quality, just slightly less expensive, it’s Brillux. Alpina is too expensive but not better. All three paints cover excellently and apply well, with a nice creamy consistency. A primer like Go on Tiefgrund is sufficient. It is yellow and dries clear, yellow so you can see where you have already painted.
Nordlys
13 Nov 2017 13:50
The idea of using a primer mixed with heavily diluted wall paint is good.
Malz1902
14 Nov 2017 07:22
Should latex paint be used for the bathroom and guest toilet?
