ᐅ Requesting feedback on our floor plan design
Created on: 25 Mar 2017 10:46
KingSong
Development Plan / Restrictions none, neighboring buildings
Plot size 882m² (9489 ft²)
Slope slight south-facing slope, about 1.5m (5 feet) drop over 34m (112 feet) length towards the south
Floor area ratio none
Plot ratio none
Building lines and boundaries none
Edge development yes, garage
Number of parking spaces 2
Number of floors 2 full stories, ground floor clear height 2.70m (8.9 feet), upper floor clear height 2.50m (8.2 feet)
Roof type gable roof 28°
Style
Orientation east / west
Maximum heights / limits
Additional requirements
Homeowners’ Requirements
Style, roof type, building type gable roof, modern interpretation of a Jura-style house
Basement, stories slab on grade, 2 full stories
Number of occupants, ages 4 people: M 42, F 35, F 4, F 3
Space requirements ground floor, upper floor ground floor 100m² (1076 ft²), upper floor 100m² (1076 ft²)
Office: family use or home office? both
Guest bedrooms per year 1-2
Open or closed architecture open
Traditional or modern construction modern
Open kitchen, cooking island open kitchen with half island
Number of dining seats 8
Fireplace no
Music / stereo wall yes
Balcony, roof terrace no
Garage, carport large garage 7m x 8m (23 ft x 26 ft)
Vegetable garden, greenhouse vegetable garden
Further wishes / special features / daily routine, including reasons why certain things are desired or avoided:
Bedroom facing north/east as it is the coolest room in the house and we like to wake up with sunrise; children’s rooms preferably separated from the bedroom; flush interior doors with 5mm (0.2 inch) aluminum frames; ground floor parquet flooring, upper floor vinyl/design flooring; bathroom tiles with wood look; the open space in the hallway on the upper floor should be a mix of a small second living room and play area for the children; circulation pump; controlled mechanical ventilation with humidity recovery; wood/aluminum windows
Planner: my 5 cents
-planner from a construction company
-architect
-do-it-yourself
What do you like most? Why? The west side, because we have an unobstructed view to the west over fields and forest
What do you dislike? Why? So far nothing
Cost estimate by architect/planner: around €430,000 excluding ancillary construction costs, including slab on grade
Personal budget limit for the house, including fittings: €480,000 including ancillary construction costs (excluding kitchen and garden)
Preferred heating technology: air-to-water heat pump or geothermal with baskets
If you had to give up something, which details / expansions
-could you do without: external venetian blinds, wood/aluminum windows
-could you not do without: the flush-mounted doors
Why did the design end up this way?
It evolved from many previous drafts and matured over time
Floor plan of a house: living/dining area with dining table, kitchen, bathroom, office, stairway, garage (above)
Floor plan of a house: bedroom, two children’s rooms, hallway, bathroom, utility room, dressing room.
Modern two-story gray house with large glass windows standing on an open meadow and fenced yard.
Modern gray house with glass facades; interior visible: dining room left, living room right.
Modern two-story gray facade with flat roof, terrace and garden fence.
Modern gray house with gable roof, garage on right and fenced green garden.
11ant17 Apr 2020 15:33
mmmmbau schrieb:
Would you happen to have a version of your floor plan in higher quality and with more measurements,
What exactly is hard to see in the one shared in post #50?
mmmmbau
20 Apr 2020 08:47
what exactly can you hardly see in post #50?
When I download the floor plans and zoom in, I can’t clearly make out the square meters, for example, and the dimensions also become blurry. Am I the only one having this issue... strange...
20 Apr 2020 08:58
mmmmbau schrieb:
When I download the floor plans and enlarge them, I can’t clearly read the square meters, for example, and the measurements also become "blurry." Is it just me having this problem... strange...
No, it’s not just you. The quality isn’t good. However, the dimensions should be clear from the drawing itself. For example, you know that a kitchen cabinet measuring 60cm x 60cm (24in x 24in) arranged in a row of five will total 3 meters (10ft). A bed is usually drawn as 2 meters (6.5ft) in length. So where is the problem? You can’t and don’t want to implement everything at a 1:1 scale anyway. Kingsong paid a lot for the design. You’re getting it here for free—so what’s the issue?
mmmmbau
20 Apr 2020 09:04
No, not just you. The quality isn’t good.
However, the measurements should come naturally when drawing, so you know that a kitchen cabinet measuring 60cm x 60cm (24 inches x 24 inches) arranged five times in a row equals 3 meters (10 feet). A bed is generally drawn as 2 meters (6.5 feet) in length. So where is the problem? You can’t and don’t want to replicate anything 1:1 anyway. Kingsong paid a lot for the design. You’re getting it here for free, so what’s the problem?
No problem... why be so sensitive? I simply asked Kingsong if he has it in better quality. If he says no, that’s fine; if yes, I’d be happy. I never claimed that I want to build the house exactly as is... that would be nonsense...
11ant20 Apr 2020 14:23
mmmmbau schrieb:
I never claimed that I want to rebuild the house exactly...
Then it shouldn’t be a problem whether you notice that the main house is only 13.51 meters (44.3 feet) wide in the extension area instead of 13.55 meters (44.5 feet). I don’t recognize every single square meter figure either. But if you have the approximate dimensions (for example, 13.55 x 9.55 meters (44.5 x 31.3 feet) for the main house and 9.00 x 6.00 meters (29.5 x 19.7 feet) for the garage), you can roughly measure everything else as well. You don’t need the exact first decimal place of every measurement if you’re not aiming to rebuild it exactly.
