ᐅ Requesting feedback on our floor plan design
Created on: 25 Mar 2017 10:46
KingSong
Development Plan / Restrictions none, neighboring buildings
Plot size 882m² (9489 ft²)
Slope slight south-facing slope, about 1.5m (5 feet) drop over 34m (112 feet) length towards the south
Floor area ratio none
Plot ratio none
Building lines and boundaries none
Edge development yes, garage
Number of parking spaces 2
Number of floors 2 full stories, ground floor clear height 2.70m (8.9 feet), upper floor clear height 2.50m (8.2 feet)
Roof type gable roof 28°
Style
Orientation east / west
Maximum heights / limits
Additional requirements
Homeowners’ Requirements
Style, roof type, building type gable roof, modern interpretation of a Jura-style house
Basement, stories slab on grade, 2 full stories
Number of occupants, ages 4 people: M 42, F 35, F 4, F 3
Space requirements ground floor, upper floor ground floor 100m² (1076 ft²), upper floor 100m² (1076 ft²)
Office: family use or home office? both
Guest bedrooms per year 1-2
Open or closed architecture open
Traditional or modern construction modern
Open kitchen, cooking island open kitchen with half island
Number of dining seats 8
Fireplace no
Music / stereo wall yes
Balcony, roof terrace no
Garage, carport large garage 7m x 8m (23 ft x 26 ft)
Vegetable garden, greenhouse vegetable garden
Further wishes / special features / daily routine, including reasons why certain things are desired or avoided:
Bedroom facing north/east as it is the coolest room in the house and we like to wake up with sunrise; children’s rooms preferably separated from the bedroom; flush interior doors with 5mm (0.2 inch) aluminum frames; ground floor parquet flooring, upper floor vinyl/design flooring; bathroom tiles with wood look; the open space in the hallway on the upper floor should be a mix of a small second living room and play area for the children; circulation pump; controlled mechanical ventilation with humidity recovery; wood/aluminum windows
Planner: my 5 cents
-planner from a construction company
-architect
-do-it-yourself
What do you like most? Why? The west side, because we have an unobstructed view to the west over fields and forest
What do you dislike? Why? So far nothing
Cost estimate by architect/planner: around €430,000 excluding ancillary construction costs, including slab on grade
Personal budget limit for the house, including fittings: €480,000 including ancillary construction costs (excluding kitchen and garden)
Preferred heating technology: air-to-water heat pump or geothermal with baskets
If you had to give up something, which details / expansions
-could you do without: external venetian blinds, wood/aluminum windows
-could you not do without: the flush-mounted doors
Why did the design end up this way?
It evolved from many previous drafts and matured over time
Floor plan of a house: living/dining area with dining table, kitchen, bathroom, office, stairway, garage (above)
Floor plan of a house: bedroom, two children’s rooms, hallway, bathroom, utility room, dressing room.
Modern two-story gray house with large glass windows standing on an open meadow and fenced yard.
Modern gray house with glass facades; interior visible: dining room left, living room right.
Modern two-story gray facade with flat roof, terrace and garden fence.
Modern gray house with gable roof, garage on right and fenced green garden.
11ant26 Mar 2017 15:48
KingSong schrieb:
I think the stage of wandering aimlessly is already over for us,
I don’t think so, because there is hardly a more typical symptom than this:
KingSong schrieb:
Obviously, this design is a completely different house, but what you can’t know is that this house was already on the radar right from the start and was only changed again and again due to countless impressions gained along the way... and I am capable of learning, the "old" design was basically optimized to death by me until I showed it to you for the first time yesterday. So I hope that the original plan is still the better alternative... between this first plan, which the current one is based on, and the plan from yesterday, there are a lot of intermediate versions...
With the phenomenon of returning to the origin, you are—in all times and countries, I would almost say—in very good company.
By the way, I also experience this very regularly in the business sector: after twenty years and four rearrangements, almost all desks in office buildings (for the first time) end up pretty much exactly where the architect originally placed them on the plans.
kbt09
26 Mar 2017 17:02
Overall, I also like the layout of option 2. However, I noticed the following points:
  • How is the kitchen going to be furnished? I like the kitchen’s position.
  • Walk-in closet... how much wardrobe space do you need? I think there is too little wardrobe space possible here.
  • A bathroom with two doors always seems problematic to me, and I’m also interested in how the bathroom furniture will be arranged.
  • Floor-to-ceiling windows in children’s rooms are usually rather counterproductive, since desks and other furniture have to be placed somewhere and often end up in front of these windows. I prefer wider windows with standard sill height, possibly with somewhat narrower windows on the east/west side.
  • Windows with high sill height in the living area tend to create more of a basement feeling inside.
26 Mar 2017 17:07
Break away from symmetrical facades. After all, you probably don’t want a townhouse or a traditional coastal-style house. It’s perfectly fine for two windows serving separate rooms to be next to each other but offset on the facade. Windows inside rooms don’t have to be centered; they should be positioned to allow enough space for furniture.
Are you sure you want to look out of a window while bathing? For bathroom windows, consider a high horizontal window strip so that no one can look in.
Best regards in brief
KingSong27 Mar 2017 07:31
kbt09 schrieb:
I generally like the layout of option 2 as well. However, I noticed the following points:
  • How is the kitchen supposed to be furnished? I like the kitchen’s position.
  • Walk-in closet ... how many wardrobes do you need? I think there isn’t enough wardrobe space here.
  • A bathroom with two entrances always seems problematic to me, and I’m also curious about the bathroom furniture.
  • Floor-to-ceiling windows in children’s rooms often seem counterproductive because desks and such have to be placed somewhere, often right in front of these windows. I’d prefer wider windows with a standard sill height, possibly narrower windows on the east/west sides instead.
  • Windows with a high sill height in the living area tend to give more of a basement feel inside.
The kitchen will be fitted on the right side with four full-height cabinets flush with the wall; at the bottom (the south side) there will be a 4m (13 feet) long kitchen run facing the dining area, turning 90° back into the room. So, a U-shaped layout. The kitchen run on the south façade should also be flush with the wall and will have upper wall cabinets installed. I will visualize this soon using the Ikea planner.
The walk-in closet actually has room for two units of 3.50m (11.5 feet) height wardrobes. We are choosing not to include a window in the closet since we usually only use it early in the morning or late in the evening. For all other times, there is more than enough lighting available.
Yes, the bathroom with two entrances is a bit of a concern, but my dear wife doesn’t want to walk naked through the hallway (although I wouldn’t mind).
I’ve taken your advice about the children’s room windows into account—it sounds reasonable. Regarding the two windows in the living room, I don’t think they will create a basement feeling; I’ve already seen several living rooms with this type of window, and we actually want the living area to feel somewhat separate and cozy—kind of like a hideaway.
kbt09
27 Mar 2017 13:07
Then you still need to adjust some of the dimensions
  • 240 cm (94 inches) tall cabinet wall; you should plan for just under 250 cm (98 inches) to allow for plaster, etc.
  • 400 cm (157 inches) kitchen run … but there is less than 400 cm (157 inches) to the sliding door
  • 2x 350 cm (138 inches) wardrobes in the dressing room … there is a window shown, so we can’t assume it will be removed. Currently, the room is only 334 cm (131 inches) wide.
  • Try furnishing the bathroom.
KingSong27 Mar 2017 13:20
Oops... I had removed the window in the dressing room yesterday, but I forgot that it’s still in the plans here.
Yes, I agree with you @kbt09, the measurements are not yet 100% final. As I said, this is just my "paper sketch" for the architect, and we will work it out together in detail. It was mainly about the room layout, windows, proportions, etc.
I’m also considering whether the hallway on the ground floor really needs to be 150cm (59 inches) wide between the stairs and the wall, or if 120cm (47 inches) would be enough. That way, I could move the kitchen/office wall a bit to the right without losing much office space and would gain some extra space in the kitchen as well.
