ᐅ Requesting feedback on our floor plan design
Created on: 25 Mar 2017 10:46
KingSong
Development Plan / Restrictions none, neighboring buildings
Plot size 882m² (9489 ft²)
Slope slight south-facing slope, about 1.5m (5 feet) drop over 34m (112 feet) length towards the south
Floor area ratio none
Plot ratio none
Building lines and boundaries none
Edge development yes, garage
Number of parking spaces 2
Number of floors 2 full stories, ground floor clear height 2.70m (8.9 feet), upper floor clear height 2.50m (8.2 feet)
Roof type gable roof 28°
Style
Orientation east / west
Maximum heights / limits
Additional requirements
Homeowners’ Requirements
Style, roof type, building type gable roof, modern interpretation of a Jura-style house
Basement, stories slab on grade, 2 full stories
Number of occupants, ages 4 people: M 42, F 35, F 4, F 3
Space requirements ground floor, upper floor ground floor 100m² (1076 ft²), upper floor 100m² (1076 ft²)
Office: family use or home office? both
Guest bedrooms per year 1-2
Open or closed architecture open
Traditional or modern construction modern
Open kitchen, cooking island open kitchen with half island
Number of dining seats 8
Fireplace no
Music / stereo wall yes
Balcony, roof terrace no
Garage, carport large garage 7m x 8m (23 ft x 26 ft)
Vegetable garden, greenhouse vegetable garden
Further wishes / special features / daily routine, including reasons why certain things are desired or avoided:
Bedroom facing north/east as it is the coolest room in the house and we like to wake up with sunrise; children’s rooms preferably separated from the bedroom; flush interior doors with 5mm (0.2 inch) aluminum frames; ground floor parquet flooring, upper floor vinyl/design flooring; bathroom tiles with wood look; the open space in the hallway on the upper floor should be a mix of a small second living room and play area for the children; circulation pump; controlled mechanical ventilation with humidity recovery; wood/aluminum windows
Planner: my 5 cents
-planner from a construction company
-architect
-do-it-yourself
What do you like most? Why? The west side, because we have an unobstructed view to the west over fields and forest
What do you dislike? Why? So far nothing
Cost estimate by architect/planner: around €430,000 excluding ancillary construction costs, including slab on grade
Personal budget limit for the house, including fittings: €480,000 including ancillary construction costs (excluding kitchen and garden)
Preferred heating technology: air-to-water heat pump or geothermal with baskets
If you had to give up something, which details / expansions
-could you do without: external venetian blinds, wood/aluminum windows
-could you not do without: the flush-mounted doors
Why did the design end up this way?
It evolved from many previous drafts and matured over time
Floor plan of a house: living/dining area with dining table, kitchen, bathroom, office, stairway, garage (above)
Floor plan of a house: bedroom, two children’s rooms, hallway, bathroom, utility room, dressing room.
Modern two-story gray house with large glass windows standing on an open meadow and fenced yard.
Modern gray house with glass facades; interior visible: dining room left, living room right.
Modern two-story gray facade with flat roof, terrace and garden fence.
Modern gray house with gable roof, garage on right and fenced green garden.
11ant25 Mar 2017 20:44
KingSong schrieb:
Oh, I think we are misunderstanding each other about the plan... so the stair nosing is on the right, the staircase is open on all sides, and there is no wall that projects 60cm (24 inches).
The wall = the left stringer of the staircase coming from between the kitchen and utility room juts out forward of the stair nosing by the depth of the kitchen run. Anyone coming from the front door and turning toward the stairs – which I personally don’t like, as I would prefer the stair axis to align directly with the path from the front door (if you want a turn, you wouldn’t build a straight-flight staircase) – ends up with the corner of the wall “behind their back” as they turn. At this point, people sensitive to Feng Shui often experience a kind of emotional imbalance akin to a tilted pelvic bone.
House floor plan with dimension details, walls in blue and red lines
25 Mar 2017 20:54
First of all, I like that you have planned space for wardrobes in the important rooms. I really like those recesses in the children’s rooms.
The staircase: does the drawn wall between the stairs and the dining area actually exist? Is it only supposed to run underneath the stairs?
What kind of railing is planned on both sides?
If I have understood correctly, I find the entire living area rather uncomfortable because when sitting, you always have the entrance in view. Also, I am not happy with the huge window. I do like generous and bright spaces with plenty of windows, but a window should suit the room and be in proportion to the walls.
I do not like any of the four elevations either; all the windows are too wide in relation to the walls, and the different sill heights don’t match given the same window size.
The walk-in closet is too narrow: with a width of only 95cm (37 inches), how can you get a good overview of the clothes?
I also don’t like the utility room located behind the bedroom. And if you say that it doesn’t bother you when your teenager wants to drop off their smoky clothes after late nights and has to walk through your bedroom, then I wonder what intimacy means to you. I think this was the dead end in your planning that you are now trying to justify.
Basically, I feel a cloakroom is missing, as well as more privacy in the living area. The lounging corner at about 3.XX meters (around 10 feet) is a bit too short in proportion to the entire length of the room.
I don’t believe the garage will be approved as planned. Given its length and the roof covering, I would not design this corridor between the garage and the house like this. We also have a 2-meter (6.5 feet) corridor between the two, but I would only cover it with a transparent roof.
Edit: I do like the gallery space upstairs.
Regards,
Yvonne
kbt09
26 Mar 2017 01:52
You should double-check the staircase. There should probably be 16 risers, which would make the staircase about 430 cm (170 inches) long. Currently, 14 risers are shown.
26 Mar 2017 12:00
Where exactly is north anyway?
You mention an "unobstructed view" to the west, so I assume the panoramic window is in the dining area. Then you talk about northeast for the parents' rooms... I can’t quite put that together!
Best regards in brief
KingSong26 Mar 2017 12:11
As the floor plan is oriented, south is at the bottom... The glass sliding door from the dining room should open onto the south terrace... But no worries, I took your feedback to heart and completely redesigned the plan... Will share it during the day.
26 Mar 2017 12:16
Thank you
KingSong schrieb:
...But don’t panic, I took your feedback to heart and completely redesigned it.... Will be available during the day
An architect rarely completes a full design in one day.
A layperson can often come up with several drafts in a single day.
Best regards briefly
