moribundus15 Sep 2017 14:37Hello everyone,
I’m new here and not quite sure if this is the right place for my question.
Here is my situation: I’m currently searching and have found a large apartment at a great price.
So far, it was used as an art studio and only has a sink and a toilet in the bathroom, which is probably why it’s so affordable.
I can only view the property on-site on Monday, but I wanted to ask if you think it’s possible to install a new water connection here, or if it would be possible to branch off from the existing sink and then continue with a wall-mounted installation? Or would it be better to break open the wall? But how can I find out where the pipes are laid?
Regarding the drain, I’m hoping there is a floor drain with a grate, as in most toilets, and maybe it is positioned conveniently enough that I could use it for a bathtub, if possible?
Or connect to the sink or toilet, if that would work?
Also, I’m interested in how cost-effective this could be and what costs I might expect just for the plumbing work — excluding breaking up tiles, closing, plastering, and re-installing, etc.
Unfortunately, I don’t have any pictures yet but will share them later. I just wanted to get your opinion first.
I understand that I need the landlord’s approval, that a professional should carry out the work, and so on — I am only looking for an assessment of feasibility and potential costs.
Thank you in advance!
Chris
Chris
Pipes can be located, for example, by knocking or using a divining rod.
Knocking is done either to find cavities directly or by placing your ear against the wall while someone taps on the sink. However, this method is more guesswork than precise detection.
Alternatively, you can open up the wall and floor to trace the water pipes backward. Repairing the plaster (including smoothing, sanding, etc.) is always possible if you have the skills; otherwise, hire a professional. You just need to work carefully and repaint afterwards.
I wouldn’t hope for the best but rather prepare for the worst-case scenario.
Are you planning to do all this yourself? If not, I would suggest involving the plumber early on to discuss their ideas. It might also be worth getting a second opinion.
In principle, you can branch off supply lines, provided there is enough pressure in the pipe. You can also connect to the same drain, as long as it is large enough to handle all fixtures draining at the same time.
