ᐅ New Garage Construction Question Regarding Window Reveals
Created on: 8 Sep 2020 20:00
Hobbymaurer123H
Hobbymaurer1238 Sep 2020 20:00Hello everyone
I am new to the forum and impressed by all the information available here. We are building a bungalow with a double garage. The house is from a prefab house manufacturer, and the garage will be built by ourselves. I have mostly finished the masonry work. My question now is what material I should use to plaster my reveals and lintels before the windows are installed.
Thanks in advance and best regards,
Alex
Alex
I would apply the exterior plaster after installing the windows, and interior plaster is usually not done in a garage at all – what material are you using for the walls?
Hobbymaurer1239 Sep 2020 07:06The garage is built with Poroton blocks. My question does not concern the interior or exterior plastering, but only the reveals and lintels. I have often seen that the reveals were pre-plastered before installing the windows and doors. I assume this is to even out any irregularities.
pffreestyler9 Sep 2020 07:53Do you mean the smooth screed that is applied inside the house to create an even surface so the window sealing tape can be attached? In a garage, if it is not insulated, it probably doesn’t matter whether it is 100% airtight. Or am I mistaken?
Hobbymaurer1239 Sep 2020 08:26Exactly what I mean. It doesn’t have to be 100% airtight since the garage is unheated. I just want it to be done properly. But if this is only about attaching the sealing tape, then I can skip the work, right?
Oh, I meant filler, not plaster. For a garage outside the thermal envelope, I wouldn’t be too picky even about the sealing tape. Cars don’t catch colds.
