ᐅ New construction, basement insulation, cement plaster, bitumen coating?
Created on: 2 May 2012 21:16
skuehmiche
skuehmiche
2 May 2012 21:16
I have the following question:
What is the common procedure nowadays for new construction? I asked two people and got three different opinions ;-)
Either bitumen primer, thick bitumen coating, insulation, and then the dimpled membrane
or
cement render, bitumen coating, insulation, and then the dimpled membrane?
Basically, it’s about whether I should plaster the masonry first and then apply only the bitumen coating, or skip the plaster and replace it with the thick bitumen layer.
Which option is better or more cost-effective?
Thank you very much
JH-CADArchitekt
5 Jul 2012 10:22
What is the plaster for? I would go with the first option...
Der-H
18 Aug 2012 19:26
In my opinion, neither of the two options is completely optimal.
Since I am currently working on a construction site where we are applying the building waterproofing, I would recommend the following approach:
- Primer coat on the bare masonry
- Waterproofing membrane (make sure it is two-layered!)
- Sealing penetrations (e.g., electrical, gas, telephone, etc.) with liquid applied membrane
- Insulation (installed in two layers to prevent thermal bridges at the joints)
- If necessary, a drainage sheet (dimpled membrane) if the insulation is not water-resistant/water-repellent
If you want to be absolutely sure, you can also install edge strips at the top and bottom of the waterproofing membranes, although in my opinion this makes little sense, as the weight and pressure of the soil should prevent the membranes from sagging anyway.
