ᐅ Since the wall connection, my KALLAX unit no longer sits flush.
Created on: 8 Nov 2020 10:23
fijan
fijan
8 Nov 2020 10:23
I have a KALLAX shelving unit from IKEA and noticed that since I fixed it to the wall, it no longer sits flush against the wall stop. More precisely, while the shelf touches the wall, the cabinet does not lie flat against it at the front. Instead, the front protrudes slightly forward, leaving a small gap between the wall and the shelf, even though I placed it directly against the wall stop.
The unit is properly aligned, and the feet are level on the floor. I double-checked the instructions for mounting the wall bracket and followed them exactly as stated. Nevertheless, the front is not fully flush with the wall anymore. The shelf appears to be shifted forward by about 1 cm (0.4 inches), which looks visually unappealing and might potentially cause stability issues.
Does anyone have experience with this problem? Is there a known cause, such as irregularities in the wall stop, manufacturing tolerances of the shelving unit, or an installation pitfall I might be overlooking? I would have expected the shelf to sit perfectly flush when properly positioned and aligned. Perhaps someone can provide detailed tips on what might be causing this and how to fix it.
PAR63
8 Nov 2020 11:07
Hello fijan,
I can help you based on my own experience and some background knowledge about KALLAX units and their wall mounting. Basically, there can be several reasons why your shelf no longer fits flush after attaching it to the wall.
1. Wall irregularities: Even if the wall looks straight at first glance, many walls have small uneven spots or slight protrusions. This can prevent you from aligning the shelf completely parallel to the wall or floor.
2. Manufacturing tolerances: KALLAX shelves are generally quite precise, but small dimensional deviations always occur. Especially if the base frame or the back panel is not made 100% to size, the shelf can stand crooked.
3. Mounting of the wall bracket: The fasteners on the wall and the shelf must be perfectly aligned. If screws or wall plugs are not positioned exactly right, or if the wall bracket is slightly tilted, the shelf will shift slightly forward or backward.
4. Floor unevenness: Even if the feet stand flat on the floor, a slight slope in the floor can cause the shelf to “tilt” and therefore not sit flush at the front.
My advice:
- Use a spirit level horizontally and vertically to realign the shelf including the wall bracket.
- Check the wall for irregularities using a long ruler or straightedge.
- It might help to place small plastic wedges behind the shelf to adjust it perfectly.
- Sometimes it is unavoidable that the shelf sticks out slightly if the wall is not completely straight.
If you want, feel free to describe exactly how you attached the wall bracket; maybe there is a small mistake that is easy to fix.
I hope this helps you!
tra_nina
8 Nov 2020 14:52
PAR63 schrieb:
Use a spirit level along the length and height to realign the shelf including the wall brackets.
That is a good first step. Additionally, I would systematically check whether the wall is truly perpendicular to the floor, as this is often underestimated.
If the wall connection profile at the floor is slightly out of place or crooked, the entire shelf cannot sit flush even if assembled correctly. I recommend measuring the corner angles with a carpenter’s square or a precise angle measuring tool.
Furthermore, the gap between the wall and the shelf should be measured at several points to determine whether the shelf is tilted or if there are localized deformations on the wall bracket.
Finally, twisting of the shelf itself can also play a role—especially when multiple units are connected or heavy loads are unevenly distributed. In this case, the front can slightly bend outward.
The more precise the analysis, the more targeted the corrective measures can be.
Parbo
9 Nov 2020 08:36
Hello fijan,
to assist you better, it would be helpful if you could provide the dimensions of your KALLAX configuration – for example, whether you have a single 4x4 module or a combination of several shelves.
Furthermore, I’m interested in how you mounted it to the wall: What type of screws and wall plugs did you use, and what material is your wall made of? Concrete or masonry? If the screws are not placed at the ideal distance, tension can develop quickly, causing the shelf to warp.
Here is a common procedure I recommend:
1. Check the wall with a long spirit level or straightedge for any dents or bulges.
2. Before mounting, verify that the shelf itself is straight and not warped (if necessary, use a spirit level directly on the edges).
3. Place the screws for the wall bracket while considering the wall’s expansion (for example, slightly varying distances between the upper and lower fastenings may be necessary).
4. After installation, measure the alignment – is the shelf still not flush? Then a slight adjustment of the feet (using washers or height shims) can help.
5. Finally, check whether the wall bracket is sitting straight, as otherwise it can effectively “bend” the shelf.
If you want, I can try to create a very detailed guide with tips for adjustment based on your wall and shelf situation. The key is careful inspection of the fastening points and avoiding tension caused by incorrect pressure during mounting.
rekijan
9 Nov 2020 20:11
tra_nina schrieb:
If the wall connection profile at the floor is slightly offset or crooked, the entire shelf cannot sit flush despite correct assembly.
Good point! I had exactly the same problem with my KALLAX. In my case, the wall was not completely straight near the bottom, and the floor had slight unevenness, which made it look like the shelf was sticking out a bit at the front.
A simple trick I used was putting small felt pads or rubberized furniture coasters under the front feet – this allowed me to tilt the shelf slightly so it would sit flush against the wall at the front. Not rocket science, but it makes a visible difference.
Sometimes a small, fine adjustment during assembly helps more than trying to get the wall perfectly straight. 🙂 Good luck!
