ᐅ My Kallax unit became stained after cleaning – how can I fix this?
Created on: 3 Aug 2020 09:22
Tradorina
Tradorina
3 Aug 2020 09:22
I recently gave my Kallax shelf a thorough cleaning because it was a bit dusty. I used a mild cleaner that was supposed to be suitable for wood surfaces according to the instructions. However, I’ve now noticed some blotchy spots on a few areas that weren’t there before. The stains look darker and somewhat shiny in places, which makes the surface uneven in appearance.
My question is: What’s the best way to even out or remove these spots without damaging the surface? Are there any proven methods to reverse discoloration caused by moisture or cleaning products on Kallax units? I’d rather avoid sanding the whole thing since it has a melamine-coated surface rather than a painted finish.
What has your experience been, and what would be the best way to limit the damage? Thanks in advance for your advice!
Garthre
3 Aug 2020 10:11
Hello Tradorina,
stained spots after cleaning melamine-coated furniture are unfortunately quite common, especially if the cleaning products used were too wet or too aggressive. Often, this results in a difference in sheen or even slight discoloration.
An effective step would be to rub the surface repeatedly with a soft, dry cloth to remove any residues.
If that is not enough, you can try using isopropyl alcohol – it often dissolves deposits without damaging the melamine surface. Be sure to test it first on an inconspicuous area.
Direct sanding is not an option because it would damage the protective coating.
These stains usually occur due to trapped moisture or leftover cleaning agents. It is important to let the surface dry thoroughly afterward and, in the future, only wipe with a slightly damp cloth and avoid aggressive cleaning products.
Renegi
3 Aug 2020 11:08
I would recommend wiping down with a damp cloth and some vinegar water. This neutralizes residues. Then let it dry thoroughly.
REPITAR
3 Aug 2020 12:45
Hello Tradorina,
I have some more experience with melamine-coated furniture and its care. Stained spots after cleaning often occur because of:
1. Excess moisture seeping into the edges, causing discoloration.
2. Using inappropriate cleaners that damage the surface or leave residues.
Here is a multi-step suggestion:
- Step 1: Immediately dry the affected areas thoroughly with a dry microfiber cloth.
- Step 2: Use a mild cleaner, for example, a neutral all-purpose cleaner, heavily diluted, and gently wipe the surface again.
- Step 3: If differences in gloss are still visible afterward, apply isopropanol (rubbing alcohol, 70%) on a lint-free cloth and carefully rub the spot – this can often remove residues without damaging the plastic.
- Step 4: After cleaning with alcohol, make sure the surface is completely dry, preferably in a well-ventilated area.
I advise against mechanical methods such as sanding or applying varnish or oil. This can completely damage the melamine-coated surface.
If the stains are very stubborn, special furniture polishes or waxes for plastic coatings can often improve the appearance but should only be used as a last resort.
Common mistakes:
Garthre schrieb:
Direct sanding is not an option due to the coating
Be careful not to damage the surface. I’m curious to hear how it goes for you!
marmar50
3 Aug 2020 15:04
Use vinegar or diluted denatured alcohol to gently clean the stains, then allow to dry thoroughly. This method has worked well on my melamine-coated furniture.
raquel52
4 Aug 2020 08:37
From my perspective, extreme caution is necessary with melamine-coated surfaces. These surfaces are splash-proof but not completely waterproof. Excessive moisture can cause permanent warping or discoloration effects.
The best approach is:
- Clean only with a lightly damp cloth
- Use pH-neutral household cleaners
- Avoid abrasive or alcohol-based products without prior testing
For existing stains, an isopropanol test may help, as already suggested. Alternatively, you can try special furniture cleaners designed for plastic surfaces that can remove residues.
Important: Allow the surface to dry thoroughly after cleaning, as prolonged residual moisture can also cause stains. Attempts to visually correct stains are difficult to predict, but if there are light discolorations, you might try a furniture touch-up pen intended for laminate.
