I have a problem with my Malm bedside table from Ikea: a piece of the plastic trim on the edge is coming off and is about to crumble completely. I was already aware that the material can be fragile in such areas, but I would like to repair it before it gets worse.
My question is: what is the best way to glue this plastic back together?
I want to make sure the adhesive is not too aggressive, as it could deform the plastic or damage the surface. At the same time, the bond should be as strong and durable as possible, since the bedside table is used frequently. Does anyone have experience with suitable adhesives or techniques for properly repairing this type of material?
It is also important to me that the repair is as neat and invisible as possible, meaning the glue should remain barely visible and ideally dry clear.
Thanks in advance for your tips!
Hello suklo,
Your question about gluing the plastic covering on the Malm nightstand is justified, as the plastics used are often difficult to repair.
In general, I recommend using a plastic adhesive based on polyurethane or a two-component epoxy adhesive. Both provide a permanent, strong bond without damaging the material.
It is important to thoroughly clean and lightly sand the bonding surfaces beforehand (with fine sandpaper) to improve adhesion. Also, apply the adhesive sparingly and press the parts together firmly during curing, preferably with clamps or heavy objects.
Do you know what type of plastic your Malm is made of? This could help narrow down the choice. Sometimes it is ABS or rigid PVC. For ABS, there are also special adhesives available at craft or hardware stores that work well and dry nearly invisible.
If you like, I can also provide product names I have already used.
tyson51 schrieb:
Recommendation: plastic adhesive based on polyurethane or epoxyThat sounds really helpful! I once repaired a similar bedside table and found it amazing how well a special adhesive holds! :-)
One more tip from me: patience is key! Adhesives often need time to fully cure, so don’t put any stress on the joint too soon.
And don’t worry, with a bit of practice you’ll definitely get the hang of it – after the repair it’s often hardly noticeable. Take your time and be careful, and it will surely work out! 🙂
Good morning everyone,
I’d like to add to the topic with a simple step-by-step guide on how to cleanly and effectively repair a Malm nightstand:
1. Preparation: Gently clean the detached plastic area with lukewarm water and a little dish soap. Then let it dry thoroughly.
2. Sanding: Lightly roughen the bonding surfaces using very fine sandpaper (grit 400-600). This greatly improves adhesion.
3. Choose adhesive: For ABS or similar plastics, a cyanoacrylate glue (super glue) designed specifically for plastics or a two-part epoxy adhesive works well. Cyanoacrylate sets quickly, while epoxy is stronger and more durable.
4. Apply adhesive: Use sparingly and only on the area to be glued. Don’t apply too much to avoid overflow.
5. Secure: Press the parts together firmly so no gaps remain. Small clamps, grips, or even a rubber band can be used.
6. Let cure: Depending on the adhesive, do not stress or move the item for about 12 to 24 hours.
7. Finishing: Remove any excess glue with fine sandpaper and, if needed, touch up the color.
To keep the repair as invisible as possible, you can gently round the edges of the bonding surface with a soft cloth before gluing to prevent the adhesive from running into cracks.
If you like, I can recommend specific adhesives I use for this kind of repair.
