ᐅ MALM Furniture and Moisture – What Is the Best Way to Handle It?
Created on: 8 May 2020 09:23
TENUNU
I am currently facing an issue with slight moisture appearing on my IKEA Malm furniture in the bedroom, especially along the edges and partly on the back of the drawer fronts. The indoor air quality is fairly normal, but I often experience slightly higher humidity levels in winter. My question is: What is the best way to minimize or even prevent these moisture damages without harming the furniture? Are there any specific tips for dealing with moisture on Malm furniture, especially since it is made of particleboard with a foil laminate?
I would be interested in advice on preventive measures, what to do if moisture marks are already visible, and whether any particular care products or methods have proven effective. Thanks in advance for your suggestions!
PECLARISSA8 May 2020 18:42bauku schrieb:
Moisture absorbers, which you can find in any hardware store, are real lifesavers!Absolutely, these little helpers should not be missing in any room prone to dampness! 😊
Also, a tip from me: if possible, wipe the furniture occasionally with a dry microfiber cloth. It easily absorbs moisture without damaging the surface.
And: if you have a dehumidifier, it’s worth running it for a few hours during winter – it works wonders to keep the air dry and helps extend the lifespan of your furniture.
TENUNU schrieb:
The edges have become a bit softer, but without visible swelling.This is a critical issue: once the edges start to soften, moisture has already penetrated the material. Prompt action is essential.
My recommendation:
1. Air out the furniture immediately and increase the distance from the wall.
2. Carefully sand the edges with fine sandpaper to remove any loose fibers.
3. Then apply a sealing, water-repellent finish or a special furniture resin. There are products available at hardware stores with water-repellent additives specifically for chipboard furniture.
4. Always test the product on a scrap piece first to ensure it does not discolor the laminate.
5. If the inside of the drawers is damp, ensure airflow there as well and check the contents if necessary.
One more question: Are the furniture items permanently exposed to the exterior wall due to condensation, or does the problem only occur occasionally after airing out?
TYRELL schrieb:
Treat edges this way and keep distances from the wallGreat tips! I’d like to add my favorite advice: After airing out the room, gently dab your furniture with a cloth if it feels cold or damp.
I know it sounds like extra work – but it really helps. And if you do this regularly, your furniture often avoids the worst damage 😉
Also, don’t forget: Humidity in basements or on exterior walls is usually higher. A small space heater on cold days can work wonders. But don’t point it directly at the furniture; rather, use it indirectly to create dry air 🙂
