ᐅ Looking for cable trunking and distribution box in RAL 1015 (light ivory) color.
Created on: 24 Sep 2019 08:37
Radomiro
Radomiro
24 Sep 2019 08:37
Hello!
Like most, we spent a lot of time planning the lighting outlets for our terrace. Unfortunately, we now have to work with some cable trunking and a junction box on the exterior wall.
The wall is plastered in the base color Maxit Muskat 5540, and after several attempts (under different lighting conditions), RAL 1015 seems to be the closest match. So now we are looking for cable trunking and a junction box in this color.
The hardware store just shrugged, and despite all efforts, I can only find online shops that offer either "cable trunking" or "RAL 1015," but never both combined in one product. The only one I found is "Kabelkanal Pipeline" (EAN 4317784541305), but at 2.5 mm by 12 mm (outside), it is far too narrow.
Does anyone have any ideas or tips?
Thanks!
Fummelbrett!
24 Sep 2019 10:02
Is painting the conduit and the electrical box in this color not an option?
Fuchur
24 Sep 2019 15:53
Paint can be custom mixed accordingly.
danixf
24 Sep 2019 16:29
tehalit cable duct systems. A product catalog can be downloaded from the Hager website. There are really attractive options available.
Everything in paint! For Hager project solutions, an almost unlimited color palette is available: approximately 210 RAL colors, 1,700 RAL design colors, over 1,600 Sikkens paints (based on 4041 Color Concept), about 1,500 NCS paints, 14 DB colors, 80 sanitary colors, as well as manufacturer-specific blends or powder coatings with a metallic effect. Simply provide us with the exact manufacturer’s color code or send us a color sample – and we will give your solution a customized finish.
Standard colors: RAL 9010, pure white RAL 9001, cream white RAL 7035, light gray GALV, galvanized other RAL colors available on request
Surcharges for custom paint finishes in RAL colors for aluminum and sheet steel materials
per color and order: 10% of the net product value, but at least €100.00 net.
A few quotes from the brochure.
Radomiro
24 Sep 2019 21:00
Fummelbrett! schrieb:
Is painting the duct and the box in this color not an option?
That is so ... obvious, I just hadn’t thought of it until now. You would have to wait and see if the paint holds, but it should probably be very easy to implement. RAL 1015 paint is available in almost every finish, surely also suitable for plastic cable ducts. Thanks for the idea!
danixf schrieb:
tehalit cable duct systems. You can download a product catalog on the Hager website. There are really nice options there.
That is basically possible too. But it seems a bit oversized to me, and "on request" usually means expensive.
