DragonyxXL7 Sep 2015 12:51We are currently working on the floor plan for a bungalow. The bungalow features a rectangular kitchen/living area, which can be accessed through two openings on one of the longer sides of the rectangle (approximately 6 x 8m (20 x 26 ft)). We are considering having this room entered via a step down. The terrain slopes slightly downward from the entrance toward this room, but probably not by a full step height (16/17cm (6.3/6.7 inches)). How would such a design be constructed, and what consequences could this have—especially regarding costs?
Bauexperte7 Sep 2015 13:40DragonyxXL schrieb:
We were considering entering this room via a step down. The ground slopes slightly downward from the entrance toward the mentioned room, but probably not as much as a full step (16/17cm (6.3/6.7 inches)). How would this be constructed, and what would the implications be, especially in terms of cost?This is known as a split-level design; it creates an interesting interior perspective but, unfortunately, due to the earthworks involved, it is an expensive option when building a single-family house. Depending on the soil conditions, the size of the "lower" level can easily add between approximately EUR 10,000 plus 15% extra on top.Regards, Bauexperte
One step:
It can look good if it’s separated. I definitely wouldn’t recommend it for the main living area, as you would be forced to overcome this obstacle multiple times a day if it’s in the main traffic route. If at all, only for a fireplace corner or another separate area that is not used frequently, and then with care.
At first glance, the hallway looks far too long and unnecessarily extended, with a cramped dining area in return.
DragonyxXL8 Sep 2015 19:48Thank you for the feedback. The earthworks alone should not be particularly expensive if we are only talking about an additional 10-15cm (4-6 inches). Does anyone know how this would or could work with the foundation slab?
Bauexperte8 Sep 2015 22:53DragonyxXL schrieb:
The earthworks alone shouldn’t be particularly expensive if we’re only talking about an additional 10-15cm (4-6 inches). So why are you asking if you are the expert?
Regards, Bauexperte
