ᐅ Laminate Flooring Over Existing Tiles
Created on: 14 Jul 2008 14:12
we have tiles throughout the entire ground floor. Now, I would like to install laminate flooring. Does anyone know if I can just lay the laminate directly over the tiles with an underlayment for sound insulation? Or are there any other preparatory steps needed, or is it simply a matter of placing a soundproofing underlayment (how thick??) and then the laminate on top?
Thank you very much!
Bobo-1
19 Nov 2008 08:02
I imagine that some heat loss could occur when laminate is laid over tiles. Since insulation also needs to be installed underneath to reduce sound transmission, this could prevent the heat from the tiles from transferring properly to the laminate. I would rather suggest using a carpet, as it is not as thick!
Mattia-1
19 Aug 2015 08:05
In any case, remove the tiles here. This may be tedious, but the effort is worth it. The impact sound insulation can then be significantly reduced.
Karl-Steffen-1
30 Dec 2015 11:33
Of course, you can lay the laminate over the tiles. However, that doesn’t offer many advantages. The tiles should be removed first, and then you can install the laminate. I would also recommend skipping the impact sound insulation.
