ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
aero2016
5 Apr 2019 18:37
@aero2016
If you address someone personally and confront them, you should name the right person. If you are too careless with that, you should avoid it. For clarification, here is the post you are referring to:
Thank you for your comment, but it is incorrect. I have assigned it correctly. Maybe it was not easy for you to understand.
Nordlys
5 Apr 2019 19:09
...and I no longer discuss Haydee's bottles because they simply do not concern me.
haydee
5 Apr 2019 19:31
@hampshire
Your kitchen is different from those shown here, just like your house.
I like it.
@Nordlys and @ypg Thank you.
Bookstar
5 Apr 2019 20:43
I won’t post my kitchen here because it is very unconventional. According to my kitchen builder, he only sells something like this once every 10 years. But hey, whatever—I still like it a lot, and that’s all that matters (modern country-style kitchen without wall cabinets, featuring a cooking island and a built-in French door refrigerator).
Yosan
5 Apr 2019 20:49
We will also have a kitchen in the country house style. What exactly is meant by a modern country kitchen?
Nordlys
5 Apr 2019 21:04
Country-style kitchens feature carved lion heads as decoration and are traditionally made from oak, while modern versions use bamboo.
