ᐅ KALLAX becomes wobbly after several times of rebuilding – Will glue help?
Created on: 13 Jun 2017 10:23
Youssef8Hello everyone,
I have taken apart and reassembled my IKEA KALLAX shelving unit several times now because I’m redesigning different rooms. However, I’ve noticed that the unit has become a bit wobbly. The joints are no longer as tight as they were during the first assembly, and the shelf shakes slightly, especially when I move it or open loaded compartments.
My question is: Can wood glue, PVA glue, or other types of adhesives help to make the unit more stable again? Or is this ineffective or even counterproductive for KALLAX because of its connection method? I want to avoid damaging the unit or reducing its stability.
Has anyone had experience with tightening a KALLAX unit after multiple disassemblies and assemblies? Which types of glue, if any, are appropriate? Thanks in advance for your advice!
Hello Youssef8,
First of all, to be clear: the KALLAX shelf is designed for one-time assembly, which is reflected in the material and connection methods. With repeated assembly and disassembly, the joints (usually the dowels and pegs) wear out and no longer fit as tightly.
Regarding your question about glue: in principle, you can use wood glue to reinforce the joints. Please keep the following in mind:
1. Wood glue (PV system) works well for solid wood and laminated panels. KALLAX is made of particleboard with a melamine coating, so the adhesion is not very strong at specific points, but it does help.
2. If you glue the parts, you won’t be able to easily take them apart afterwards. This is important to consider if you plan to reassemble the shelf later.
3. Clean the surfaces thoroughly before gluing to ensure good adhesion.
4. Press the shelf firmly together after applying the glue and allow it to dry sufficiently (at least 24 hours).
5. Alternatively, you can use special wood glues made for coated boards or construction adhesives that create a stronger bond.
Summary:
Glue can definitely help make the KALLAX shelf more stable if the joints become loose from repeated assembly and disassembly. However, the shelf will then be a permanent installation and lose its flexibility for future moves or changes.
If you don’t want to fix the assembly permanently, your best option is to assemble carefully and thoroughly, and replace any damaged dowels if necessary.
I hope this helps!
Summary:
I hope this helps!
Hello Youssef8,
It's great that you are approaching this topic so thoroughly. I would like to explain the technical details a bit further to clarify why the KALLAX shelf wobbles after being assembled multiple times and where a glue solution can help.
The core of the problem lies in the type of connections used: KALLAX employs pre-made dowel holes and metal fasteners (metal brackets or cam connectors) that, together with the dowels, provide stability. These connection points are designed for only a few assembly cycles, as the dowels and particleboard material suffer from fraying and indentations.
When a shelf becomes wobbly, it is often due to the following factors:
- Worn dowel holes from frequent disassembly and reassembly
- Loose metal fasteners or their screws
- Reduced clamping force at the joints after multiple disassemblies
Regarding glue:
1. Wood glue such as PVAC adheres to wood fibers and penetrates them. Particleboard, however, is only slightly porous and sometimes coated with melamine, which limits the glue’s bonding surface.
2. In KALLAX, the connections primarily rely on mechanical interlock (dowels + metal fasteners) rather than adhesion. Glue is effective only if the parts are firmly clamped together and the bonding surfaces are properly coated.
3. The biggest risk when using glue is that the melamine coating may soften or delaminate due to the moisture in the glue, especially if too much glue is applied, which can cause long-term damage.
4. If you decide to use glue, it is recommended to apply a thin layer of high-quality wood glue and allow for a long clamping time without load. This will make the shelves more stable but will also make assembly and disassembly very difficult or impossible.
5. Alternatively, you might consider replacing the dowels (e.g., with new, tighter-fitting dowels), tightening screws, or adding additional brackets.
Therefore, my recommendation is:
- If you intend to keep the shelf assembled permanently, you can carefully use glue but check the surfaces beforehand.
- For flexible assembly and disassembly, glue is generally not suitable.
- Check that the metal fasteners are tight and replace worn ones.
If you like, please share how often you have reassembled the shelf and whether you have already replaced any parts?
Regarding glue:
Guyju schrieb:
Glue can definitely help make the KALLAX shelving unit more stable if the joints have become loose from frequent assembly and disassembly.Exactly! But keep in mind: after that, the shelf will be really inflexible! 😉
Sometimes, simply tightening the screws or furniture connectors properly again helps before resorting to glue.
And if you do decide to use glue: don’t apply too much, so the melamine coating doesn’t soften. Also, be patient and allow adequate drying time.
deoke schrieb:
You can also replace the dowels with new ones or add extra brackets.Great tip! Sometimes that’s enough to restore proper stability.
In any case: the KALLAX isn’t designed for frequent disassembly. So if you plan to rebuild it often, better to choose other shelving systems. ;-)
