ᐅ Kallax: What to do when the shelves start to sag?
Created on: 4 May 2016 18:27
Naupo
Naupo
4 May 2016 18:27
I have an IKEA Kallax shelf unit that I have been using for about two years. Recently, I have noticed that the shelves—the insertable shelves—are becoming increasingly saggy, meaning they are less stable and bend slightly when I place items on them. In my opinion, the load is not excessive; I store books, binders, and a few decorative items.
I am interested in learning about options to stabilize or replace these sagging shelves. Are there practical tips to extend the lifespan of the shelves without having to replace the entire unit? Maybe material upgrades, reinforcements, or replacement products?
I look forward to your experiences and suggestions.
JAPLO
4 May 2016 19:35
The issue with sagging Kallax shelves is well known and usually results from the thin particleboard used in these units.
To restore stability, I recommend reducing the load or reinforcing the shelf. A common method is to screw an additional cross brace made of wood or metal underneath the shelf to prevent bending.
Alternatively, there are replacement shelves available with a reinforced core board if you want to replace the original. However, you should make sure the dimensions are an exact match, as reproductions sometimes vary slightly.
gekira
4 May 2016 20:54
The cause of the Kallax shelves bending is the material thickness of about 12 mm (0.5 inches) particleboard, which is not designed for high point loads without additional reinforcement.
An effective and long-lasting solution is to replace the shelves with custom-cut plywood panels at least 18 mm (0.7 inches) thick. These are significantly more durable and warp less. The panels must be precisely adjusted to the internal dimensions of the Kallax unit.
Additionally, installing support strips along the longitudinal sides can widen the support surface and further reduce bending.
taMoniqu68
4 May 2016 21:16
I have had good experiences simply gluing a thin MDF board under the floor. It helps without much effort.
Alternatively, you can use metal brackets under the floor, which are attached on the sides. This provides significantly more stability.
Naupo
5 May 2016 08:12
JAPLO schrieb:
to screw an additional cross brace made of wood or metal under the shelf
Do I understand correctly that I should basically screw the brace crosswise underneath the extended section? What is the best way to fasten it without leaving visible holes on the cabinet? I want to avoid affecting the appearance.
gekira schrieb:
to replace with plywood panels at least 18 mm (0.7 inches) thick
Sounds interesting, but are the plywood panels visually noticeable? Or can I easily compare them to the original shelves? Thanks for the advice.
baelku
5 May 2016 09:47
The braces are screwed underneath the floor, yes. To avoid visible drill holes on the outside, I recommend placing the holes on the inside of the shelf, where they are hardly noticeable.
Alternatively, you can use clamp brackets that don’t require screws. These are available at hardware stores. They are almost invisible and provide good stability.
Plywood panels usually have a darker appearance and a wood grain texture. If you find this too conspicuous, you can cover them with a foil or sand and paint them.
